Cold engine runs stronger
Old Jun 7, 2004 | 07:57 PM
bri-max's Avatar
I was wondering if anyone had noticed that there max ran stronger before it completely warmed up? (I know this is an automotive no-no but it's hard to resist the added acceleration). My car has been modified with a JWT pop charger and a cattman y-pipe and just by the seat of the pants feeling I believe that it is accelerating harder than when it is totally warmed up. From my K&N equipped pop charger I am certain I am hearing a deeper intake growl. I wondered if a chip upgrade would enable my car to have this type of acceleration all of the time?
Old Jun 7, 2004 | 08:30 PM
unrealii's Avatar
Its because when your car is cold, it is running rich to warm the cats up.
Old Jun 7, 2004 | 08:35 PM
crazydave's Avatar
I noticed this same strong acceleration while driving the engine cold, however as soon as it warms up it doesn't pick up like that. What is the reason for that happening? Anyone know? Is there a way to maintain that pick-up at all times?
Old Jun 7, 2004 | 08:36 PM
Bjorn's Avatar
i thought when a car is running rich... it runs slower, and when its running leaner... it runs faster but more prone to exploding?
-B
Old Jun 7, 2004 | 09:24 PM
96maxdaddy's Avatar
It dosent run rich to warm the cats up!!! It runs rich cause the car is still in open loop. Its in open loop, till the o2 sensors kick in then it goes to closed loop. While its in open loop, the computer has NO idea how much fuel to add. So it uses info from look up tables, with info like coolant temp, air temp and info from the MAF, and calculates a reasonable air fuel ratio, which is always going to be a little rich.
Old Jun 7, 2004 | 09:29 PM
unrealii's Avatar
I stand corrected
Old Jun 7, 2004 | 11:22 PM
LiquidhMax's Avatar
I bet your sitting, so you sit corrected :P lol
Old Jun 8, 2004 | 02:17 AM
Kiosk's Avatar
its also related to colder engine having a cooler intake manifold and overall lower temperature which leades to a denser air going into the motor.....but once the air heats up it expands and its not as dense.
This is why you often see folks at the track putting ice packs on their superchargers and even pushin the car to the starting line...
Want that cold engine feeling all the time? get NOS!!!
Old Jun 8, 2004 | 04:34 AM
2001SE's Avatar
hot air is more dense...cold air is less dense
cold air mixes better with gas because its less dense
Old Jun 8, 2004 | 04:50 AM
mjk's Avatar
mjk
Head shot!!!
would not having the o2 sensor be bad on performance?? oh and cold air is more dense
Old Jun 8, 2004 | 05:12 AM
Wurf's Avatar
Kiosk is correct - you want HOT engine oil and COLD intake air. Just about all cars make more power when they are just warming up, than when they are fully warmed up, unless it's a diesel.
Old Jun 8, 2004 | 06:05 AM
Y2K1JKSE's Avatar
get an S-AFC II and play around with that...then you can run rich whenever you want...just don't get too fuel mix happy with it
Old Jun 8, 2004 | 06:51 AM
96maxdaddy's Avatar
Yeah you need the o2 sensors, cause you dont want to be running rich all the time. But you could just get one of those computer thingys so you can play around with the air fuel ratio.
By the way, mjk are those the projectors you 5th gen guys are having problems with people stealing? Cause those are sooo.............
Old Jun 8, 2004 | 07:01 AM
[maxi-overdose]'s Avatar
cold air is more dense.
Old Jun 8, 2004 | 07:40 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
get this...... www.nextlevelracing.com
maxinout93
Oct 27, 2015 01:29 PM
rtirbany
Sep 8, 2015 11:46 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
