Caliper Paint... spray or brush?
Old Jun 8, 2004 | 09:28 PM
Spudskier's Avatar
I've seen caliper paint both spray-on and the kind that is painted on with a brush... is either one better quality? does the brushed kind stay better? is the spray more metallic or glossy?
thinking of doing my sterling mist's calipers red
Old Jun 8, 2004 | 09:44 PM
Blk2kMAXSE's Avatar
Brush is way better but much more expensive. the kit that i've always used is a mixture which will make the paint kinda rubbery when cured. it is much more durable then caliper spray paints that i have used. the kit will come with 2 solutions that are mixed right before use, a can of brake cleaner and brush. i ordered my stuff from southwest autoworks. hope this helps.
Lam
Old Jun 8, 2004 | 10:01 PM
Spudskier's Avatar
Thank you!! Third post in a row with immediate answers, good advice to boot, Thanks .org!
Old Jun 8, 2004 | 11:12 PM
00MAXIST's Avatar
Go for the G2 kit. Looks as close to powdercoat as I can imagine a caliper paint job can get. It's a little more expensive then other paints but when you see it's quality you won't be dissapointed. I ordered my kit from tirerack.com
Old Jun 8, 2004 | 11:28 PM
Triple8Sol's Avatar
I miss the .org!
Spray is more than fine. I used High Temp primer, color, and clearcoat. Several quotes of each...
Old Jun 9, 2004 | 05:42 AM
desperado_45's Avatar
G2 paint is great
Just dont do red on a sterling mist I have a sterlin mist and its looks better w/ silver IMO
Old Jun 9, 2004 | 06:59 AM
ChromeSE5's Avatar
I went cheap and ghetto and used high temp black BBQ paint (stuff i had left over from the anniversary headlight mod) and it worked fine for me. With spray paint, because it goes on thin compared to enamel (very thick) you don't really have to tape up the rotor - you can directly spray onto the caliper while it is on the rotor. So I guess another plus when using spray is that there is less prep time. But I seriously think that spray will never make it look like the way the paint is on the wilwood or brembo paint.
Old Jun 9, 2004 | 01:13 PM
irish44j's Avatar
retired moderator
The G2 stuff is great - it's super thick, very tough, and has a nice shine to it (and customer service is excellent). Like desperado said, though...please don't do it in red - you don't want to call too much attention to the maxima's puny OEM calipers!
Apr 16, 2020 05:15 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
bumpypickle
Sep 19, 2015 01:07 AM
beerman1378
Sep 8, 2015 02:19 PM
