Short throw Shifter???
Old Jun 10, 2004 | 05:16 AM
Pri63's Avatar
I'm looking to buy a short throw shifter...Any recommendations? I might buy the one off of custommaxima.com.
Old Jun 10, 2004 | 05:33 AM
Kruppa's Avatar
i bought the adjustable one off of custommaxima.com and i love it
Old Jun 10, 2004 | 05:46 AM
GeneYes_Se5spd's Avatar
Cutting
Whats the difference between just cutting your old shifter and rethreading it, and buying a new one?
Gene
Old Jun 11, 2004 | 06:57 AM
ThaHotness2k's Avatar
Gene
That would shorten the stick, however the throw would only be that much shorter. If you purchase a short-throw shifter it changes the height of the shifter as well as the pivot point, which makes a huge difference in the length of the throw.
Old Jun 11, 2004 | 07:28 AM
Kiosk's Avatar
How hard was that to install? or did u have someone do it?
Old Jun 11, 2004 | 07:53 AM
max34's Avatar
Spend a little more money and get the B&M.
Trust me...I had the custommaxima.com and replaced it with the B&M.
Old Jun 11, 2004 | 08:17 AM
I put the custommaxima shifter in myself. It was my first mod and took me about 4 hours to do, mainly because I was unable to get the catalytic converter off and had to work around it. If you can get the cat off, do it. Otherwise the install was not all that bad.
Old Jun 11, 2004 | 09:29 AM
Kiosk's Avatar
Its the shifter the only actual part that changes or the whole linkage assblembly that goes to the transmission also? Thanks man
Old Jun 11, 2004 | 10:29 AM
2kSC's Avatar
Get B&M! They specialize in transmissions.
The shifter is nice and heavy. At precise ****s it shoots between gears, great performance mod.
And unless you have a lift or can get under your cat, get a pro to change it for around 80 bucks.
Old Jun 11, 2004 | 10:48 AM
Pri63's Avatar
Where can I find a B&M Shifter
Old Jun 11, 2004 | 11:05 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Try typing B&M shifters into Google.com
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
