cylinder 4 misfire
Old Jun 10, 2004 | 01:05 PM
gameover03's Avatar
cylinder 4 misfire
2000 max...81 k....My ses light is on and its reading as a cylinder 4 misfire... I replaced the coil, the spark plug, the fuel injector and maf....what else could it be?...ne suggestions..
Old Jun 10, 2004 | 01:33 PM
DanL's Avatar
Just checking, but are sure you worked on cyl #4? It's the middle cylinder on the "front" of the engine (nearest radiator). Assuming you did, the only other things I can think to check are (1) you don't have s broken coil harness/connector or (2) no intake air leaks. Have you tried a compression test yet?
Old Jun 10, 2004 | 02:21 PM
gameover03's Avatar
Yeh My Mechanic Says My Compression Is Fine....so U Think Its A Bad Harness.?.. How Much Is That?
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
