Cali Spec Owners
Old Mar 29, 2001 | 05:04 AM
Pmp-n8a's Avatar
After looking at the dyno plots of MaxGator, Ive been pondering a way to get ride of this problem.
Would the cattman headers and the jet performance ecu get rid of these problems?
Old Mar 29, 2001 | 07:09 AM
UMD_MaxSE's Avatar
Got Bent?
perhaps get a fed-spec ecu?
Old Mar 29, 2001 | 03:19 PM
Pmp-n8a's Avatar
would that even work?...wondering cause what would happen to the third o2 sensor?
Old Mar 29, 2001 | 04:09 PM
UMD_MaxSE's Avatar
Got Bent?
The fed-spec ECU would know nothing about the extra O2 sensors....But I doubt it is as simple as the ECU though....that is probably only one step in going to fed-spec emissions. Plus, getting the ECU would be no easy task either.
Old Mar 30, 2001 | 12:59 PM
Desert Pearl's Avatar
I am working on a solution for the lower performance of the CA emissions vehicle right now. I have already purchased a 1995-2000 front-side (or left hand side) exhaust manifold that I will use when I purchase a 2000 Federal spec'ed y-pipe. With this combination I will be able to remove both pre-cats in the stock y-pipe. I have relocated the downstream O2 sensors to after the main cat already, so that isn't a problem anymore. As soon as I can afford the y-pipe, I'll do the install and let everyone know how it went.
This should get rid of all of the extra restrictions of a CA emissions car compared with a federal one, except for what the ecu is doing. I am hoping that the ecu is using the same timing & A/F ratio tables that the federal car is. If this is the case, then the problem is solved.
I guess we'll just have to wait and see.......
Old Mar 30, 2001 | 01:19 PM
y2kse's Avatar
I wish you luck, Desert Pearl. My suspicion is that what you're trying to accomplish probably won't work with a CA/NLEV-spec ECU. But I hope I'm wrong.
Please keep us posted.
Old Mar 30, 2001 | 01:40 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Good luck and keep us updated!
jmlee44
Oct 2, 2022 02:13 PM
Quickywd01
Sep 21, 2016 09:36 PM
D Mason
Jun 21, 2016 04:43 AM
bernyp
Oct 2, 2015 10:10 AM
