Service Engine light is on...
Old Jun 11, 2004 | 09:44 AM
scopium
i took out the cluster..
to clean it.. put it back in.. and just rev up the car.. and service engine light came on...
how can i get rid of it?
thanks
Old Jun 11, 2004 | 12:04 PM
scopium
nobody knows how to reset the engine light?
Old Jun 11, 2004 | 12:54 PM
davidlc's Avatar
On the 2000 max, if you disconnect the battery for 45 min to an hour and reconnect, then the light should reset. I think the 2001's are the same.
Gsilk's Avatar
Reported
i believe you unplug the battery overnight? don't quote me on it however
Old Jun 11, 2004 | 01:05 PM
davidlc's Avatar
I did mine a few days ago for about 45 min and it worked.
Old Jun 11, 2004 | 06:05 PM
scopium
i've had my battery disconnected for 7 hours now.. hopefully tonite or tommorrow morning everything will be fine
Old Jun 11, 2004 | 06:12 PM
Larrio's Avatar
The Definitive AE Master
if it comes up again, i'll clear it for you at the dyno meet
Old Jun 11, 2004 | 06:19 PM
KLOOGY's Avatar
L33t BMW Drivah
I need to clear mine too.....but I was told by the dealer, that the only way to clear and reset the ECU is with the Scan thing the dealer has.......
Old Jun 11, 2004 | 06:53 PM
Larrio's Avatar
i've got an obd-II scanner now. I can check and clear codes.
the dealer uses a consult-II which is alot more advanced and has other features
Quicksilver's Avatar
OT n00bs FTMFCSL
Anyone with an OBD II scantool can erase the codes...
scopium
thanks larry.. i just reconnected my battery and it was gone.. but i would still like to know what was wrong with it.. i'll see you at the dyno meet
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
