Struts Popping
Old Jun 14, 2004 | 05:49 PM
knightmelodic's Avatar
Struts Popping
I know this has been asked before. I can't find the thread. Anyway, my KYB AGX front struts are making a popping noise over bumps. I didn't get a set of springs along with them; I got the progress springs first. I believe some one said it was the strut bearing? Will this get worse? Thanx fam.
Old Jun 14, 2004 | 08:29 PM
housecor's Avatar
Did you make sure "OUT" on the top hat is facing out? If it's your strut bearing, then you should also hear the noise when parked and the wheel is turned lock to lock.
Old Jun 14, 2004 | 08:50 PM
SE01's Avatar
Are you sure it's the strut? Check the sway bar links out to see if its them. I just replaced mine.
Old Jun 15, 2004 | 04:11 AM
ZIPPIN's Avatar
Mauja He Mauja
i installed the maxspeeds. when i take hard turns, i hear a popping noise..i was going to take off the wheel and check all the bolts etc...
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
