Code help needed: P0110 and P0105
Old Jun 22, 2004 | 08:46 AM
Compton's Avatar
Hi,
I replaced my spark plugs, ignition coils, radiator fan motor and thermostat last weekend. When I started the car back up, the SES light was on. The codes thrown were
P0110 IAT Mal
P0105 Map Cir Mal
The IAT=Intake Air Temperature but not sure what that means. I had the codes cleared by a mechanic and they haven't come back yet. Can anyone explain what the codes mean? And is this just due to replacing too much stuff at once and it temporarily trippped a code but doesnt indicate a long term problem?
Any advice is appreciated.
Old Jun 22, 2004 | 09:16 AM
Igor911's Avatar
Check out this thread:
http://forums.maxima.org/showpost.ph...11&postcount=2
Old Jun 22, 2004 | 09:19 AM
Compton's Avatar
Thanks for the link.
But what do they mean?
P0105 Absolute pressure sensor
P0110 Intake air temperature sensor
Old Jun 22, 2004 | 09:37 AM
ihavea5spd's Avatar
detects ambient barometric pressure and sends the voltage signal to the ecm. as the pressure increases the voltage rises.
problem could be the harness or connectors (sensor is open or shorted) or it could be the sensor itself.
you could try to loosen and retighten your engine ground screws.
disconnect the abs. pressure sensor harness and cehck it for water.
there are other things to check too, but you need tools to do it.
this is mounted to the air duct housing. it detects air temp and sends a signal to the ecm. this problem could also be caused by the harness, or the sensor itself. try wiggling it, or disconnect and reconnecting it. if that doesn't work, again you need tools.
Old Jun 22, 2004 | 10:34 AM
Compton's Avatar
My mechanic might have disconnected some of these things temporarily when installing everything. Hopefully that is all it is
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
