Lug Nut Torque and Measuring the torque
Old Jun 23, 2004 | 08:25 AM
Love_00_Max's Avatar
What is the correct lug nut torque for the 2K maxima and how can one know he/she has not over torqued the nuts. I want to know if there is any tool that tells me this is it -- no more torqueing.
Old Jun 23, 2004 | 08:47 AM
Zero Deuce SE's Avatar
You need one of these.
The torque is probably around 70-85 foot pounds.
Old Jun 23, 2004 | 09:27 AM
Mick Max's Avatar
Wild at Hurt
The above torque is correct.
To see how they are tightened.
Use or buy a cheapie beam type 1/2 in torque wrench
as you loosten counter clockwise see how far the indicator moves, this is how tight it is/was.
Old Jun 23, 2004 | 01:25 PM
brianc's Avatar
Nick Max -- Checking the torque as you loosen is not correct at all and I doubt you will get a reading anywhere near wher you need to be.
Say for example you live in NJ or NY or anywhere there is salt and crap on the roads. Over time the garbage may build up around your lug nuts causing them to actually feel tighter than they are. The break free torque would then be considerably higher than the true torque required to tighten them.
Just buy a torque wrench.
Actually I have never used a torque wrench on any car I've owned wheels and never had a problem (Jag, Alfa, Audi, Nissan, Isuzu, Ford, Chevy, Mercury, Benz)
Old Jun 23, 2004 | 01:33 PM
scopium
what kind of after maket lug nuts or lug locks. you guys use
AaronL
Nov 15, 2020 11:52 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
dcam0326
Sep 26, 2015 05:20 AM
