Quicksilver you were right!!!!!
Old Jun 24, 2004 | 04:06 AM
Rafe's Avatar
I tried your method of shifting and the car accelerated much faster than normal.
The only thing that spooked me was that when you shift from 1st to 2nd , the revs fly up and hit the revlimiter like you missed a gear.from 2nd to 3rd it delayed a second then caught without no problem!
I the tried it again but this time instead of shifting at 6XXX i shifted at 5800 rpm and it still hit the rev limiter , that delay from 1st to 2nd is slightly to long so the revs hit the limiter. Have you ever lifted off the gas then shift into 2nd then get back on it like you were shifting a manual?
That VB mod maybe needed for better execution of auto shifts.What do you think?
Old Jun 24, 2004 | 06:34 AM
Quicksilver's Avatar
OT n00bs FTMFCSL
Yeah, there seems to be some differences with the shifting from 1-2 on the auto 3.5 Maximas. Can't say why, but I can tell you that just leaving it in drive will only net you times in the low to mid 15's in the 1/4 mile, but shifting manually can get you to the mid to upper 14's (once you master the timing).
Old Jun 24, 2004 | 07:23 AM
Rafe's Avatar
I thought are cars run mid to high 14's for stock?
Old Jun 24, 2004 | 07:25 AM
Rafe's Avatar
I meant mid 14's for just leaving it in 4th and getting a good launch!
Old Jun 24, 2004 | 10:26 AM
krmaxima's Avatar
so what is the method of shifting?
Old Jun 24, 2004 | 11:40 AM
SEDaveMax's Avatar
So pretty much what you're trying to master is the shift delay when manually shifting the auto. Hmm...I'm gonna have to try this at the track. The best I could do was a 14.97 leaving it out of OD. So maunally shifting@5,800 so let it shift around the rev limiter?
Old Jun 24, 2004 | 03:50 PM
NizanDrivn's Avatar
You guys are gonna chew up your tranines....
Old Jun 24, 2004 | 04:27 PM
Mr. Peabody's Avatar
I also tried starting off with leaving the slap shifter in 3rd rather than 4th (or od) and it did shift much different.
Normally leaving it in D and flooring it, the shift from 1st to 2nd happens around 6200 but the shift from 2nd to 3rd takes place at 5800.
But when I started in 3rd the shift from 1st to 2nd still took place at 6200 but it then held 2nd all the way to redline at which point I let off the gas and it shifted into 3rd. I don't know how high it would have wound out in 2nd but I generally get 200K out of my cars by keeping them below the red line LOL
Old Jun 24, 2004 | 06:05 PM
BP's Avatar
BP
i agree. and i really doubt manually shifting an auto will net better accel times than leaving it in 3rd and getting a good launch.
Old Jun 24, 2004 | 07:05 PM
MONTE 01&97 SE's Avatar
I got my best time listed below by just leaving it in drive and on the launch feathering it for a sec then gunning it. I got 3 14.6*'s in a row, I got better times by just leaving mine in drive!
Old Jun 24, 2004 | 07:06 PM
I agree thats what I did and got my best times.
Old Jun 25, 2004 | 12:01 AM
bremner44's Avatar
If your looking for quicker shifting just do the "Drop Transister" mod and put a switch in so you can turn it on and off.
Old Jun 25, 2004 | 06:33 PM
OT n00bs FTMFCSL
No way man. The car will shift at 6000 RPM if left in D instead of 6500-6600 RPM when shifting manually...
Old Jun 25, 2004 | 06:37 PM
OT n00bs FTMFCSL
Well, you guys are both dead wrong. My tranny is in great shape, and is taken to the track whenever possible. I have no shifting problems, no lag, no slipping...nothing but perfect shifts time after time. And I've already (as well as every other person who has raced the 2002-2003 Max) proved that shifting manually gets you better times by at least .3-.4 seconds, if not more...
Couple this shifting method with the "drop resistor mod" and your tranny will shift better and faster (at the track-due to higher tranny line pressure) and still do anything you need for day to day driving. How else do you guys think that we auto folks are racing?
Old Jun 25, 2004 | 06:38 PM
OT n00bs FTMFCSL
That still doesn't shift you at the limiter, and the drop resistor mod should only be used for WOT shifting (aka-at the track)...
Old Jun 25, 2004 | 09:25 PM
BP's Avatar
BP
coupled with the drop resistor mod i can see how this would improve overall times. i have it installed to activate under WOT and can tell a difference. but without the drm i'm sure it becomes more difficult to manually shift an auto and get better accel than if you let computer shift. the delay and slipping between gears at the higher revs leaves a lot of room for mistake. i suppose with the drm this is eliminated but i honestly haven't tried it.
Old Jun 26, 2004 | 06:47 AM
OT n00bs FTMFCSL
Believe me, you need to. You're missing at least .2-.3 seconds off what COULD be your 1/4 mile time
deoncollins69
286
Mar 29, 2007 10:08 PM
