Audio SCV Low/Mid/High?
Old Jun 28, 2004 | 07:25 AM
skytower31's Avatar
One of the options in the audio menu on the non-bose headunit is SCV with Low/Mid/High options. I tried driving around in each mode and can't tell and auditory difference. What is this option? Manual had limited info.
Thanks!!!
Old Jun 28, 2004 | 07:28 AM
Y2K1JKSE's Avatar
that would be Speed Controlled Volume....it increases the volume of the HU as your speed increases to compensate for the road noise. and when you slow down it automatically lowers the volume back to the volume you set it at. the low/mid/high options are the sensitivity options you can choose.
Old Jun 28, 2004 | 07:37 AM
skytower31's Avatar
So the higher the sensitivity, they louder it will get with speed and the quieter it will get when you slow down?
Old Jun 28, 2004 | 07:38 AM
2k3TitaniumSe's Avatar
Does the screen also show the volume numbers changing?
Old Jun 28, 2004 | 08:07 AM
skytower31's Avatar
I hit the Audio button until it gets to SCV and then I scroll through low/mid/high. That is all. Is there some other option I am missing?
Old Jun 28, 2004 | 08:13 AM
Skier's Avatar
I can only notice a difference with it set on "high". Try setting it there, close all your windows, get on a highway on-ramp at about 30MPH to start out and stomp on it. You'll hear a difference. Iv'e found that if your not specifically listening for it you won't hear the difference. I do not see any numerical volume change on the display. I think it's because your not actaully changing the volume setting, the system is just amplifiing it a little until your speed drops again, and the volume returns to normal.
An all but useless function in my opinion.
They have this on the stereo on the Honda Goldwing, and the volume really jumps up. Set up properly on a bike it's a great function.
Old Jun 28, 2004 | 08:29 AM
skytower31's Avatar
I know cadallic has a great feature like this that will actually adjust volume, bass and treble according to the interior noises...
Old Jun 28, 2004 | 10:09 AM
jreddington3's Avatar
Its about as good as the similar system I've had on GM rental cars. You don't notice unless you're paying attention which is good, it's not obtrusive. I turned it off on my Max once and I did notice I now started tweaking the volume manually because setting it for at speed, it was too loud at idle.
Now if I could just get enough volume out of this stupid Bose system so I can enjoy the music at highway speed with the windows and roof open.
And where did they come up with the odd number of "31" as max volume. Is it 3.1 times louder than and amp that runs to "10"? I don't think so?
Old Jun 28, 2004 | 03:07 PM
ChromeSE5's Avatar
a lil off post, but does the none bose 2k2 2k3 headunit have different options than the non bose 2k 2k1? I dont have the whole low/mid/high or svc.
Or is this something with a certain edition maX? sorry for the noob question..
Eugene
Old Jun 28, 2004 | 07:55 PM
Only BOSE equipped maximas have this option.
Old Jun 28, 2004 | 08:25 PM
skytower31's Avatar
The unit in question from the original post is a non-bose unit that has the SCV.
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
