2000 Maxima
Old Jun 28, 2004 | 11:36 AM
Sewtek's Avatar
2000 Maxima
I have a New (to me) 2000 Maxima. Check engine light is on. How do I determine what code I'm getting, and how do I clear/reset this thing?
Any help is appreciated.
Old Jun 28, 2004 | 11:49 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
pull the code by hooking up an OBD2 diagnostic tester. i always suggest taking it autozone because they pull the codes for free. i have been told by some members that their autozones are charging for it but all the ones in my area, its still free. after you pull the code, get the repair done before worrying about reseting the light because most likely it will just cycle the code back out and light the cel if the repair has not been done.
Old Jun 28, 2004 | 12:04 PM
skalberti's Avatar
I live life on the edge
You can leave the Negative terminal on your battery unhooked overnight. In the morning tap yuor brake pedal a couple of times to use any residual voltage if present. Then reconnect the neg terminal to the battery. The light should be off now, unless you really have a problem, then it will trigger the SES light again. At that point I would take it in to autozone and see if they can pull the code for you
Old Jun 28, 2004 | 12:32 PM
john5820's Avatar
WOW I just got a 2000 Maxima too, and I also have that check engine light on too.
Old Jun 28, 2004 | 12:41 PM
AdamK's Avatar
havn't gotten the notorious ses light yet (in the 03) but I remember it was on so often in my old 00 that I was just gonna "mod" the light and get like a hyper white led for it or something cool like that lol,
yah unplug the neg terminal like skalberti said, then take it to the zone....also I know this is obvious but make SURE your gas cap is on nice and tight
Old Jun 28, 2004 | 07:28 PM
maxcozmo's Avatar
Get used to that light on your dash. It's going to be on alot.
Old Jun 29, 2004 | 04:26 AM
ZIPPIN's Avatar
Mauja He Mauja
take it to autozone. they will pull the code for free. post the code here and find out what the fuq is wrong with it this time
halfpol
Oct 17, 2022 12:16 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
