Rear suspension install question ..
Old Jun 29, 2004 | 09:41 AM
maxima0002's Avatar
Will be doing my install of illuminas and H&Rs this coming Thursday. Can anyone assist? Do i need to remove the black bracket (outlined in Red) before proceeding with removal of the two nuts in the strut? Seems like a VERY tight fit .. I want to make this install as seemless as possible.
Thanks for the assistance..!
max0002
Old Jun 29, 2004 | 03:35 PM
ABS's Avatar
ABS
max0002
There is no need to remove that bracket. You should be able to get to one of the strut mounting nuts from that big hole at the bottom of the bracket and the second using an extension slid through a convenient opening at the top of that same brace. I do recommend that you jack up both sides of the car at the same time, it will make removal of the lower strut mounting bolts much easier.
Old Jun 29, 2004 | 08:03 PM
Ammi's Avatar
350 Detroit Muscle
I used a long extension to unscrew. There should be enough clearance to fit behind that black bracket.
Old Jun 29, 2004 | 08:36 PM
housecor's Avatar
Nope. Don't remove it. Use long socket extensions and a U-joint to make it easy. How-to on my site.
incubusjohnny
Nov 3, 2015 05:18 PM
Huttig2009
Sep 25, 2015 03:31 PM
george__
Aug 18, 2015 07:06 PM
Team STILLEN
Aug 10, 2015 04:29 PM
