LED Window Switches & more LED lighting
Old Jun 30, 2004 | 06:04 AM
Pri63's Avatar
Check out these pics of my LED-ed interior...I hope to add some more LED lighting when I get some time...maybe even "LED"the side markers once I figure out how to. Let me know what you think
http://www.cardomain.com/memberpage/631349..SCROLL DOWN on the page
Thanks to
http://www.alexhsu.com/maxima/ledinstall/
redmax99sel
for all the help
Old Jun 30, 2004 | 06:39 AM
GaMax97GLE's Avatar
Originally Posted by Pri63
Check out these pics of my LED-ed interior...I hope to add some more LED lighting when I get some time...maybe even "LED"the side markers once I figure out how to. Let me know what you thinks
Thanks to
redmax99sel
for all the help
Looks good. For the LED side markers...get some 194 LED bulbs from here: http://autolumination.com/194.htm
That's what I did.
Old Jun 30, 2004 | 11:12 AM
sheidt's Avatar
That's what I did.
GaMax - I haven't taken off the side markers, so this may be a silly question, but, do those 194 bulbs that you referenced just fit into the slots that the existing OEM side marker bulbs were in, or do those LED bulbs need a different "housing" to plug into? Again, sorry if this is an obvious question, but I figured you could easily tell me, since you have obviously done this mod.
Old Jun 30, 2004 | 11:20 AM
GaMax97GLE's Avatar
They should slide right in.
Old Jun 30, 2004 | 11:41 AM
sheidt's Avatar
Hey, thanks GaMax! One more question, with those amber and red LED's behind the clear side covers, can you see the coloring of the bulbs through the clear lens when the bulbs are off, or are the LED's just clear, too, unless they're on?
Old Jun 30, 2004 | 11:45 AM
GLE2000's Avatar
The LEDS are clear. They come with a colored base though. I would get the ones that have 6 LEDs in the bulb. I got the single bulb ones and they are alright, but it would be better if they were brighter. You can see the colored bases a little, but you will notice on autoilluminations site you can also buy white bases to replace the colored ones if it bugs you too bad. Honestly its hard to see them through the clear corners though.
Old Jun 30, 2004 | 12:59 PM
sheidt's Avatar
GLE2000 - Thanks for the suggestion. Just out of curiosity, are the single LED bulbs that you said could stand to be a little brighter on your car the opaque that give a scattered, softer light or the clear bulbs that give a brighter, more focused light?
Old Jun 30, 2004 | 01:06 PM
Cubanato's Avatar
Joo wanna play??......ok we go to war
nice... but i did mine in white...
-J
Old Jun 30, 2004 | 01:17 PM
sheidt's Avatar
-J
I'll bet the bright-white matches up real nice with your glacier white color exterior.
Old Jun 30, 2004 | 01:19 PM
sheidt's Avatar
I was wondering if there was a special paint I could spray the clear sides with that came close to matching my titanium paint that was still translucent to let light through from the bulbs and still at least partially reflective. Just thinking about how that would look with a matching color, although I think the clear would probably look better.
Old Jun 30, 2004 | 01:20 PM
Cubanato's Avatar
yes it does and it def gives teh interior some more flavor at night.. instead of those ugly green leds
-J
Old Jun 30, 2004 | 01:24 PM
BJGemini's Avatar
On the link to the "how-to", there aren't instructions on the passenger or rear window switches.... in fact, it almost discourages you from attempting. Can you give any insight into the tricks do doing it correctly?
Thanks -
Brian
Old Jun 30, 2004 | 02:43 PM
MIXXMAX's Avatar
Thanks -
Brian
Yes, take your time and watch that you don't lose those tiny ball bearing ***** and that copper "rocker" piece inside the switch. It may take some practice in putting the switch back together. The driver's switch is far the easiest of them all.
Old Jun 30, 2004 | 02:50 PM
MIXXMAX's Avatar
Thanks to
redmax99sel
for all the help
Looks good! I did the same, but went a little further and added some blue LED's elsewhere, also....like the guage cluster and under the A/C unit.
Old Jun 30, 2004 | 06:55 PM
silvermax2k2's Avatar
Looks good man! Glad my advice helped out! By the way, i am redmax99sel from instant messenger... but when having owned 5 maxima's, it is tough changing you screen name everytime... lol.
-Chris
Thanks to
redmax99sel
for all the help
Old Jun 30, 2004 | 07:07 PM
2k3TitaniumSe's Avatar
Looks great mang. What size LED was used it the key ring?
Old Jul 1, 2004 | 03:47 AM
Pri63's Avatar
I used 3mm Blue 6000mcd LED bought off of ebay for 2.50+S&H for 20 of these bulbs. The seller was mckenkenken. I'll let you know these bulbs are bright, when my security light blink it lights up the car.
If you're going to do the key ring, you'll have to use a resistor, you can pick them up from radioshack color code is Orange, orange, brown, gold. Let me know if you need any help...
I'm also going to try and post some how-tos on the passenger switches.
Old Jul 2, 2004 | 09:42 AM
maseo77's Avatar
PLEASE tell me how u did that, my factory lights under my ac unit dont even come on anymore and i dont know how to change them.
Old Jul 2, 2004 | 10:06 AM
Thanks. Gotta buy some soon!
Old Jul 2, 2004 | 10:11 AM
thomasd cook's Avatar
Check out my homepage. I've got a write-up on all the doors and I was the first one to do the illumination light under the AC controls.
Old Jul 2, 2004 | 12:15 PM
MIXXMAX's Avatar
It's really simple. Just remove the A/C unit and remove the clear plastic trim piece where the bulb is. For mine, I left this piece removed from the unit. I then mounted the LED's on a thin plastic strip from some scrap radio trim pieces. I wired the LED's in "series" instead of running a resistor to each and every LED, because when wired individually, the LED's would be too bright at nite. My blue LED's are 5000 mcd's. PM for any other questions you may have.
Old Jul 2, 2004 | 07:56 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
where is your homepage? i want to do all doors with white LEDs, cant seem to find a good write up for it thanks!
Old Jul 2, 2004 | 08:06 PM
Pri63's Avatar
It's under the post, everyone who has a webpage has a WWW button under their post...that will take you to his homepage, see it?
mvm062
Nov 30, 2020 09:00 AM
vingodine
45
May 21, 2016 12:46 PM
MaxLife17
Sep 8, 2015 02:36 PM
A32goldylocks
Sep 2, 2015 06:39 AM
kjm900r
Aug 5, 2015 07:14 AM
