2000 spark plug write up
Old Jul 1, 2004 | 06:06 AM
Max20SE00's Avatar
I was wondering if anyone can post the link to the how to on changing spark plugs for a 2000. Thanks
Old Jul 1, 2004 | 06:31 AM
dvanorder's Avatar
You don't need it. I printed out something a year ago for when the day came, which was last week. I never touched it after taking a good look; if you have common sense, a delicate touch, and a good swivel (for 2 of the rear plugs), you will breeze through it.
Toughest part is getting the plug coils out of the rears with the connector attached--I can't seem to pull those suckers off to save my life, and I know you squeeze the key and tug. You can cut some tie wraps to give you the room, then tie them back down when finished
1. Remove the 4 hex bolts holding cover for the front 3 plugs
2. Use 10 mm socket to remove bolts holding coil packs
3. 5/8" spark plug wrench on a long extension to pull/install plugs
4. Use magnetic rod to grab/start coil pack bolts on rear plugs
5. Light touch installing plugs since you have to thread them on using the extension
Old Jul 1, 2004 | 06:41 AM
Sprint's Avatar
I got 95 - 99 with pictures which should be the same
http://www.turbomaxima.com/modules.p...iewlink&cid=25
Old Jul 1, 2004 | 07:44 AM
Max20SE00's Avatar
Anyone know what the gap is supposed to be on the plugs for a 2000?
Old Jul 1, 2004 | 07:46 AM
Sprint's Avatar
-11 plugs are pregapped
Old Jul 1, 2004 | 07:54 AM
Max20SE00's Avatar
thank you for all your help
Old Jul 1, 2004 | 12:22 PM
Sprint's Avatar
you are welcome
Old Jul 1, 2004 | 12:24 PM
UMD_MaxSE's Avatar
Got Bent?
I'd still double check the gap...
should by .044"
Old Jul 1, 2004 | 12:26 PM
Sprint's Avatar
should by .044"
hmm.. i should edit your post and show your gayness
Old Jul 1, 2004 | 12:28 PM
UMD_MaxSE's Avatar
Got Bent?
Old Jul 1, 2004 | 02:44 PM
Rich1's Avatar
Write up for 5th Gen
Here's a write up with pics I found for a 5th gen:
http://www.nissanx.net/tanman/
Hope this helps.
Rich
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
