Y Pipe ECU Reset ...Please Help
Old Jul 1, 2004 | 09:40 PM
Kruppa's Avatar
I disconnected the negative battery terminal at 2:00 a.m sharp and I have to reconnect it for work at 7:15...i have been told 3 hours is enough and i'd imagine it might not even take that long...5 hours is enough right??? Also, I have a quarter tank of regular gas left (my neighbor filled it up with regular gas after getting it serviced as a favor and i've been trying to burn it off bc i use premium)...should i fill up the rest with premium or burn the regular off as much as possible first??? i'm hoping those few miles of regular won't stop what i'm tryin to accomplish with resetting the ecu during maximum performance...??
Old Jul 1, 2004 | 09:52 PM
RichP23's Avatar
Did you just get your Y-Pipe installed? When I got mine done, I was told that the ECU would train itself... I didn't have to reset it.
Old Jul 1, 2004 | 10:29 PM
E-dUB's Avatar
i had no problems with my car without resetting my ecu after installing my cattman y-pipe. no ses light or any problems.
Old Jul 2, 2004 | 07:36 AM
scopium
you can reset your ecu if u want.. not really necessary .. but it will take a bit longer for the ecu to get used to the new mod if its not reset
Old Jul 2, 2004 | 09:53 AM
spirilis's Avatar
Dude, you don't even have to wait 1 hour -- just push the brake pedal and hold it for a few seconds w/ the battery's negative cable disconnected... that should be one way to drain any residual power left, which should reset the ECU immediately.
Old Jul 2, 2004 | 09:55 AM
spirilis's Avatar
Oh, and as for the gas... if you're down to 1/4 tank, just fill it up with premium. I seriously doubt it's going to mess with the ECU's retraining, and if it does, the ECU will eventually adjust to the premium gas anyway.
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Quickywd01
Sep 21, 2016 09:36 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
