2002 Automatic shift knob removal
Old Jul 2, 2004 | 11:15 AM
2002 Maxima SE's Avatar
2002 Automatic shift **** removal
How do you remove the shift ****? I thought it screwed on, however after applying a great deal of torque, it won't come off.
Old Jul 2, 2004 | 12:00 PM
Blu's Avatar
Blu
the tits
it screws on...might need to hit the weight room
Old Jul 2, 2004 | 12:14 PM
Donkey®'s Avatar
wat
More torque. It is on there pretty tight.
Old Jul 2, 2004 | 01:03 PM
ICELANDIC MAX's Avatar
turn it counterclockwise. should come off fairly easy. however some others have had a more difficult time getting it off.
Old Jul 2, 2004 | 07:55 PM
Nismotech1's Avatar
confident nissan owner
hey you got an auto, it does not twist off....at the bottom of the **** there is a piece of plastic you have to push down the plastic either use some kind of knife (but be carefull) or use something made of plastic, once you remove that you wil see a metal clip, when you remove that clip it comes right off. no screwing involved
Old Jul 3, 2004 | 04:17 AM
03maximan's Avatar
On the 02's and 03's they screw on and off.
Like stated above counterclockwise to remove,
mine was not too hard to unscrew though.
Old Jul 3, 2004 | 10:23 AM
krmaxima's Avatar
i want to change mine as well but i only want to change it if this one fits http://www.sounddomain.com/item/MOMF16ESIL
I need to be 100% sure because i want want to waist my money
thanks
Old Jul 3, 2004 | 05:10 PM
03maximan's Avatar
I've heard of some people using MOMO ***** on
an automatic and they fit fine.
Old Jul 3, 2004 | 07:03 PM
vsamoylov
i took mine off today. it s screwed on.
Old Jul 4, 2004 | 09:03 AM
2k3TitaniumSe's Avatar
Those MOMO shift ***** look great and they will fit!
Old Jul 4, 2004 | 09:51 AM
krmaxima's Avatar
thanks and r u 100% sure? and without modding the shifter right?
Old Jul 4, 2004 | 10:21 AM
vsamoylov
anybody know the website for all momo products ?
Old Jul 5, 2004 | 02:44 PM
So which is it? Mine has a plastic piece at the bottom. I tried turning the leather **** counter-clockwise but it would not budge.
Old Jul 5, 2004 | 05:43 PM
Nismotech1's Avatar
everyone says it screws off, so they must be right i'm the only dummy who thinks there is a clip, on an automatic vehicle at my dealership i have had to remove or push down on the plastic piece letting it sit at the bottom of the post, and then you will see a metal retainer clip that can be easily removed by a pair of needle nose pliers, then the **** pulled right off with no problem, but i may not know what i'm talking about seeing as everyone else says they screw off, hope i could help.....
Old Jul 6, 2004 | 02:42 AM
Blu's Avatar
Blu
the tits
the gated shifter on the 02-03 screws on like a manual shift ****. I've replaced mine with a momo phantom shifter...
Mar 12, 2020 12:06 AM
2kmaximel
Sep 16, 2015 03:19 PM
Colossus
Sep 9, 2015 05:46 AM
