maintenance work
Old Jul 2, 2004 | 03:25 PM
scopium
maintenance work
sup guys..
what maintenance work do i REALLY need to do at 45k..
except oil change..
i looked at the service manual.. and its just bunch of inspections..
is there anything else?
Old Jul 2, 2004 | 03:29 PM
R.I.P. Grandma's Avatar
You can rotate your tires, check your tire pressure, lubricate, check your air filter, coolant, etc....
Hope this helps.
Old Jul 2, 2004 | 04:44 PM
cobymoby's Avatar
stuff I personally would do at 45K:
oil/ filter
air filter but for you it doesn't apply
coolant
brake fluid
for the coolant I would just drain the radiator, refill and bleed the air out of the system. You'll get about 45% of it but it's better than nothing. In order to properly flush all of the coolant you have to take of the engine mounts to get to the coolant drain plugs. There are two of them for the front and rear of the engine. It's not the best way to do it but you'll be fine since you are doing it at a good interval.
If you do decide to drain the block you'll need to get some 6 pt sockets, they look like giant torx heads. That is what the drain plugs are on the block.
Regads,
Bryan
Old Jul 2, 2004 | 05:43 PM
Ammi's Avatar
350 Detroit Muscle
I would replace tranny fluid too
Old Jul 3, 2004 | 12:28 AM
cobymoby's Avatar
Oops! Forgot about that one!!
Go with Mobil1 synthetic if you have an auto. 10x's better than the Nissan Matic-D.
Old Jul 3, 2004 | 06:44 AM
ZIPPIN's Avatar
Mauja He Mauja
pcv valve. clean the throttle body
Old Jul 3, 2004 | 07:22 AM
scopium
thanks guys..
i always change my oil with Mobil Synthetic.
and i changed my tranny oil at 40k with Redline
but i got a New tranny now so i dont think i need to do it again..
and also ... as far as greasing the hinges.. what kind of grease should i use
Old Jul 3, 2004 | 01:52 PM
Ammi's Avatar
350 Detroit Muscle
I just spray some WD-40
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
