Installing rear sway and front strut soon . . . :-)
Old Jul 7, 2004 | 05:50 AM
Kruppa's Avatar
Progress rear sway bar and OTTO front strut bar are on their way and I can't wait to put them on...I'm not lowering my car however because i already bottom out from time to time no matter how careful i am (which is very very careful) in worcester when at college the majority of the year bc no matter where you go the roads suck pretty badly...i'm hoping there is still a significant increase in handling and severe lacking of body sway around corners. :-) Opinions???
Old Jul 7, 2004 | 05:57 AM
maximo-SE's Avatar
i have otto front strut bar, and Progress RSB. I can feel the RSB working, but the front didnt make much of a difference. My friend did tell me that my steering wheel wass a bit stiffer than his with the FSTB on though... so i dunno.
These are great low budget mods though. Highly recommended.
Old Jul 7, 2004 | 06:02 AM
MaximaPolak's Avatar
Nice choice....
Old Jul 7, 2004 | 06:47 AM
smoon629's Avatar
Kruppa, where did you buy each one and how much did you pay for each? thanks
Old Jul 7, 2004 | 06:51 AM
NJ Devils Fan's Avatar
Maybe you don't feel that much of a difference with the fstb because you didn't lift the car off of the wheels. I remember my friend telling me that there isn't going to be much of a difference at all unless you lift the car off the ground and put it on.
Old Jul 7, 2004 | 06:52 AM
He bought the FSTB at SWA.....
Sway bar at Custom Maxima.....(it's good to have a girlfriend at times, huh?)
Old Jul 7, 2004 | 08:13 AM
smoon629's Avatar
thanks polak, i had another question. does the progress rsb require any shaving? or is it a direct install? when you install the fstb and rsb, let us know how it goes!
Old Jul 7, 2004 | 09:03 AM
maximo-SE's Avatar
its a direct install for the RSB.
I got the FSTB from procarparts, and the RSB from the Cattman GD we had a while back...
Old Jul 7, 2004 | 09:06 AM
maximo-SE's Avatar
hmmm.. this is something to think about... so i just jack up the front two wheels, and just install it again i guess....
Old Jul 7, 2004 | 09:09 AM
NO...that's not how you install it....you want the car to be flat on the ground...
If you pick it up the two fenders will be farther appart....why would you want that? You want the strut bar to pull the fenders in not out
Old Jul 7, 2004 | 09:43 AM
SoonerFan's Avatar
Cletus
i have the exact same ones. love them!!! RSB is like night and day. i cant tell much diffirence with the FSTB but it looks cool.
btw, RSB isnt exactly a direct install. you have to relocate the e-brake line. it comes with a ziptie to hold it in place. its a very easy install
Old Jul 7, 2004 | 10:17 AM
maximo-SE's Avatar
ok so i just install it while the car is on the ground. I did that. Ill just stick with it then.
Old Jul 7, 2004 | 10:41 AM
smoon629's Avatar
what about the otto FSTB. does that require any shaving? ive read somewhere that one brand of FSTB's require you to cut a piece off. is this the case with the OTTO? thanks
Old Jul 7, 2004 | 10:44 AM
SoonerFan's Avatar
Cletus
i have a 2000 GLE and it went right on. no problems at all.
Old Jul 7, 2004 | 10:52 AM
smoon629's Avatar
are you referring to the OTTO FSTB?
Kruppa, when you get the FSTB and the RSB, post if they include install instructions. THANKS!
Old Jul 7, 2004 | 05:29 PM
2k3TitaniumSe's Avatar
Nice choice. I have the same set up and I'm very happy with it.
Old Jul 8, 2004 | 04:40 AM
silversurfersg's Avatar
how do you get under there if its flat on the ground. Im going to use ramps
Old Jul 8, 2004 | 06:32 AM
SoonerFan's Avatar
Cletus
yes. the otto FSTB went on with no problem
Old Jul 8, 2004 | 07:57 AM
MaximaDisciple's Avatar
I used ramps to put mine on, but it'd be a whole lot easier if you can put it on jackstands and remove the rear wheels. The e-brake is behind the wheel so its pretty hard to reach with the wheels on.
Old Jul 8, 2004 | 08:28 AM
SoonerFan's Avatar
Cletus
ok people are getting the RSB and FSTB mixed up.
FSTB - flat surface, not lifted
RSB - can be lifted. jackstands are the easiest
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
