Attn; Some 2000, all 2001 Owners....Front beam stiffeners.
Old Apr 2, 2001 | 07:11 AM
RussMaxManiac
Thanks to The New Climax for picking these up for me at Southpoint to bring to our SC install we did. I installed them on my car. I now see why they removed them from the 2001s. There is the AC (CAN looking thing, forgot the name) that they relocated from the driverside to in front of the condenser on the passengerside. It is located right in the way where the beam goes but not so much out of the way that it makes it impossible to fit. Basically the install went well. Removed the bolts on the lower mounts that it connects too on both sides, connected those first. Driverside was easy, no modications, but the passengerside I had to get it around that canister. I got some washers, about 4 I think put them on that long bolt so it would push that beam out more when tightend. Well it worked. I was able to tighten it down with it slightly against the canister but not smashing it, just touching it.
Handling, response difference is very very hard to tell. To what I can tell, the car still leans but gets to a point where it stops and doesn't lean near as much as it use too. Seems just a little more responsive, but this is very hard to tell. I think its a recommened add on for just 30 bucks total.
Now I just need to get my fuel line cover shield...since my tank when I filled it up, had tons of dirt inside...uggg.
I do have some detail pics I will post late tonight...
Old Apr 2, 2001 | 07:49 AM
beaglemax's Avatar
Please post pics. I am not quite sure what you are talking about.
Old Apr 2, 2001 | 08:45 AM
max2001se's Avatar
Thanks for the update Russ. I guees if its real hard to tell the difference then I'll stop worrying about it!
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
AaronL
Aug 8, 2020 10:31 AM
TKHanson
Nov 24, 2018 01:39 AM
Tmax78
Sep 25, 2015 09:07 PM
