Greddy EVO II, No O2 Sensor
Old Jul 20, 2004 | 10:55 PM
wcasskicker's Avatar
I was installing Greddy EVO II on my 2k max and found out that the mid pipe has
no O2 sensor plug. The engine light will be on one day, I just don't know when.
Does ppl with Greddy have same problem?? Reseting the ECU won't work right?
Thanx
Old Jul 21, 2004 | 12:56 AM
PO-POMAX2K's Avatar
I had the same problem. I had to get a muffler shop to weld on a coupler fro the o2 senser ($15) and the shop also did inspections so they reset the ECU. Apparently you can also reset the ECU by disconnecting the Negative cable to your Battery overnight.
Old Jul 21, 2004 | 01:29 AM
cobymoby's Avatar
It's not so much that the Greddy is missing the O2 bung, your car has an "added" O2 sensor. You have a Federal Spec maxima like Po-pomax2k does.
He had to go through the same thing you are. But like he said, just get the O2 bung welded in there and you are good to go.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
