2.2 drop
Old Jul 22, 2004 | 03:53 PM
mclarengts1's Avatar
2.2 drop
with a 2.2in drop in the front and 1.7 in the rear do you have to do any camber ajustments
Old Jul 22, 2004 | 06:16 PM
VQ30DES's Avatar
I take it your talkin about the tein S-Tech springs which is 2.2'' and 1.6'' drop. The answer is no. I have the s-techs with the illuminas (awsome set-up) and i bought an eibach alignment kit, but then relized i didn't need it, so i did not install it. When i took my max in for an alignment the camber was still within the specified limits.
Old Jul 22, 2004 | 09:01 PM
JC_2k_SE's Avatar
do you have any pics of this setup?
Old Jul 22, 2004 | 09:37 PM
Ammi's Avatar
350 Detroit Muscle
you can check out my page
Old Jul 23, 2004 | 11:33 AM
how do i get to your page
Old Jul 23, 2004 | 11:34 AM
do you think that drop is too much for 20's
Old Jul 23, 2004 | 12:35 PM
studman's Avatar
20s.... um.... that's a little extreme. I've heard of 18s and 19s on them, but 20s? Truthfully, if you keep the outer diameter the same as the stock's diameter, you can do it. But you'd be talking about a really really small sidewall. I personally wouldn't do it.
As for the drop, I've got pictures on my web site with my car on 18s on the drop. If you went with 20s, the diameter stays the same, but the sidewall of the tires would be much smaller. I currently run 235/40ZR18s on mine. I'd assume on 20s that you'd be near a 20-30 sidewall. That's too close for me.
Old Jul 23, 2004 | 12:42 PM
yeah i'd be running 245/35 20.... or 245/45 20
Old Jul 23, 2004 | 12:48 PM
studman's Avatar
IIRC... 245s will rub in the front. I've got 235s on the there now. I can't remember if 240s will rub, but I'm almost 100% sure that 245s will rub in the front
Old Jul 23, 2004 | 12:55 PM
really thanks for the info well noted
Old Jul 23, 2004 | 01:59 PM
026spdMax's Avatar
Question VQ30DES,
I have Tein S-Techs with GR-2s and the ride is getting progressivly worse. I know that it is from the struts being week. However I also had an issue from day one with front struts bottoming out on med size potholes or bumps, even on the freeway. My question to you is do you have that problem with the Illuminas. Hopefully they are stiff enough with an ok ride for the travel of suspension that is left in the front. I have always driven lowered cars and this is the worse I've ever had.
It's between the Illums and D2 coilovers.
BTW I did trim my bumpstops
Old Jul 23, 2004 | 02:05 PM
Mick Max's Avatar
Wild at Hurt
Click the profile button under his post then click on home page
Old Jul 23, 2004 | 02:23 PM
JC_2k_SE's Avatar
this issue is only for the 20s right?
Old Jul 23, 2004 | 03:28 PM
yeah but ive seen peolpe with 20's that dont scrub
Old Jul 23, 2004 | 05:24 PM
studman's Avatar
No. This applies to all sizes. 245 tires will rub in almost every single case, regardless of rim size. There may be a few exceptions, but I don't know what they are.
Old Jul 23, 2004 | 05:36 PM
Ammi's Avatar
350 Detroit Muscle
I'm running 245s but I don't have rubbing issues. I'm running 18x8.5 rims.
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
Turbonut
46
Oct 21, 2015 08:28 PM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
