Y-Pipe Noise?
Old Jul 23, 2004 | 11:14 AM
NewLoveI30's Avatar
Y-Pipe Noise?
I installed my Cattman y-pipe a few weeks ago and have been noticing that I get a lot more engine noise. I am not talking about the change in exhaust note, but an increase in engine noise. I dont think I am making it up either. If I am driving next to a wall and give it some gas, there seems to be a lot of a... Racket. This is only under load, so if I just rev the engine in neutral it sounds nice.
When installing the pipe I did shear a bolt off of the front EM/ pre-cat connection, but there was enough of the bolt left to get another nut on and crank it down, so I dont think it is that.
It sounds like there is a slight rattling with this noise aswell and I dont think it is knocking. I know it sounds like I may be answering my own question, but when I was putting a new nut on the front pre-cat I noticed that one of my O2 sensors had come loose and I dont think I remembered to crank that down. So the rattle could be comming from there.
Anybody else experience an increase in engine noise (not exhaust) with the installation of a y-pipe?
Old Jul 23, 2004 | 12:02 PM
Ferbs02SMMax's Avatar
Not a squeak. I had a shop install it though, and they didn't report any difficulties in install aside from having to lengthen wires for the 02 sensors. Hmm. Even though its a pain, you may wanna r/i again and make sure you go over everything meticulously...
Old Jul 23, 2004 | 12:17 PM
scopium
yea i get that noise.. too.. but i've checked everything.. the install was fine..
Old Jul 23, 2004 | 12:30 PM
Luquire's Avatar
same here and i have a warpspeed so i think you are fine but check the 02 sensors anyways, it should only take 15 minutes. A jack and a flash light......badabing
Old Jul 23, 2004 | 10:23 PM
dextterity's Avatar
I have a warpspeed y-pipe and am experiencing some noise, but i'm pretty sure it's some heat sheild which i couldn't remove, hopefully that's the problem, and hopefully i'll be able to take care of it when my car goes on a lift for suspension work
Old Jul 24, 2004 | 12:39 AM
DonGfun's Avatar
VW = 30 MPG
Mine sounds like it is vibrating or hitting something too right under the center console if some one finds the answer let me know
Old Jul 24, 2004 | 04:24 AM
Stev02
A few buddies and me installed my Budget y-pipe last week. I already had a custom cat back installed. Once that baby was on, my car now sounds like a BEAST. No knocking, just *****. Maybe it's the brand?
user 11122324
42
Jul 18, 2022 03:35 PM
Quickywd01
Sep 21, 2016 09:36 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
