Is Brembo rotor "much" heavier than stock rotor?
Old Jul 25, 2004 | 04:28 PM
kclmax2k1's Avatar
Hi,
I just installed the front brembo blank rotors and Raybestos® Quiet Stop pads today. So far, no noise, good stop. However, I notice that the acceleration is slower than before now. Is brembo rotor much heavier than stock rotor? Or I didn't install my pads well?
Old Jul 25, 2004 | 04:45 PM
Ben's Avatar
Ben
I just put brembo blanks on a few weeks ago. I didn't notice any weight difference or any change in acceleration.
I think it would have to be a faily significant weight difference for the 'ol butt dyno to notice. Maybe your pads are actually rubbing all the time? *shrug*
Old Jul 25, 2004 | 06:02 PM
Mick Max's Avatar
Wild at Hurt
kcl they gotta be within an ounce or 2 because they are the same dimension as stock.
Old Jul 25, 2004 | 06:31 PM
kclmax2k1's Avatar
thanks Guys, I will check my brake pads again.
BTW, what's the symptom of the rubbing pads.
i didn't hear any noise when driving and the brake worked well.
Old Jul 28, 2004 | 03:29 PM
Love_00_Max's Avatar
You are right, I too felt the Bremho rotors were heavier and my accerleration was a bit tight. I don't know why that is the reason .
Anyway to check if the pad is always on the rotor -- with no accerleration the car should move fwd i.e your leg off the brake. Also after a long drive you may want to visibly see that the rotors are not red which would mean the pins are not moving. May need to reinstall and put some sync high temp grease on it..
Hope that helps.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
jaydot901
Sep 29, 2015 01:18 PM
Socalstillen
Sep 26, 2015 12:01 PM
