Which Oil?
Old Apr 4, 2001 | 07:57 AM
bcannon's Avatar
I have been using Mobil 1 Synthetic. Synthetics are okay for the maxes, right. Are there any better oils than Mobil 1, I know that's what porsche and corvette use to fill up the first time.
Old Apr 4, 2001 | 08:08 AM
djmaxski's Avatar
Well, seeing that I am going the Mobil 1 route after 10k miles I would have to agree. I think some of the other synthetics are pretty good too, but I've always heard that Mobil 1 is the way to go (and not just from TV commercials).
Old Apr 4, 2001 | 08:10 AM
DKNYchinito
agreed
Old Apr 4, 2001 | 09:01 AM
[maxi-overdose]'s Avatar
Originally posted by DKNYchinito
agreed
guys, I thought we are not supposed to use synthetic oil for a new car. Synthetic is too smooth for new engine and it doesnt break in the new engine properly. I heard it is recommanded to use synthetic after ur car hit 20k+. I use castrol.
Old Apr 4, 2001 | 09:07 AM
bcannon's Avatar
I started the synthetic at 15...
Old Apr 4, 2001 | 09:46 AM
nisMAXse's Avatar
I've stuck with PennZoil over the years. I'm currently using PennZoil's Synthetic. Can I really run an extra 3000-3500 miles before changing this stuff out?? Is it bad to go back and forth between normal and synthetic oil...?
Old Apr 4, 2001 | 09:55 AM
djmaxski's Avatar
This has been discussed before.... Yes, you can go longer on synthetic oil (BMW claims to run for like 18000 or something without any problems). However, I don't believe that you can keep switching... I think that once you go synthetic, its best to stick with it.
Old Apr 4, 2001 | 10:10 AM
Jeff92se's Avatar
I'm needing a caw
That should be plenty of miles for synthetic. Yes synthetics last longer than dino oils. You should be able to switch between synthetic and dino but why would you?
As long as the synthetic is a REAL synthetic(ie.. Mobil 1, Amsoil, Redline), there's not alot of differences between them.
Old Apr 4, 2001 | 03:45 PM
DenMax's Avatar
I've heard it's ok to start a car off with synthetic, but not to switch older cars over to synthetic after a lot of miles. This is because the molecules in the regular oils are larger than that of the synthetic, so the synthetic can get through any little gaps that the old oils may have not been able to. thus, exposing new leaks that were "plugged" by the molecules in the regular oil. I've heard that from a couple of people with high performance vehicles, but some of them owned American so they might be a little lower on the IQ meter than the rest of us.
Old Apr 4, 2001 | 05:54 PM
sascuderi's Avatar
Synthetic
I started using Mobil 1 at 200 miles in my 2000 I30. My understanding is that in todays engines you can use it from the get go.
Old Apr 4, 2001 | 06:48 PM
silvermaxd's Avatar
I put amsoil in at 5k miles...so we'll see if anything happens.
Old Apr 4, 2001 | 08:06 PM
Mad_Fox's Avatar
the oil is not what is important. the filter is why we change oil. most filter will wear out after 3k and need to be changed. most oil (anything API and SAE certified) will outlast the filter, but is changed anyway because you have to drain it in order to get the filter off. As for brand names I would by the cheapest stuff possible, and heres why. ALL oil sold in the US is made in one of three plants. that means that Pennzoil is the same exact oil as brand X (as long as it has both SAE and API logos on it).
bottom line save money on oil and get a good filter and change it every 3k. also BIG tip DO NOT beat on(burnouts, races, etc) a new car until the engine has ran at low RPM's for 100 hours. if you do you run the risk of not machining out the cylinders and you might snag a ring on the cylinder wall... very bad engine go boom!
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
