MAF problems
Old Aug 5, 2004 | 09:25 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
MAF problems
If the MAF is bad will this make the engine sounds like a leak on the exhaust? In my car the exhaust is fine lo leaks but the engine sound is too loud when I accelerate no matter how fast or slow I drive.
Old Aug 5, 2004 | 04:08 PM
Lontar1's Avatar
Anyone has any idea
Old Aug 5, 2004 | 06:21 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Originally Posted by Lontar1
Anyone has any idea
shouldnt sound like anything. either the maf is on its way out which can cause stumbling and poor wide open performance or its completely bad and the car will not rev past 2.5k rpms or so.
Old Aug 5, 2004 | 07:03 PM
Lontar1's Avatar
Thanks man... I will have to keep looking for the engine sound that it is actually bothering me a lot......
thanks again
Old Aug 5, 2004 | 07:11 PM
sloppymax's Avatar
thanks again
do you have any exhaust mods? i had a y pipe on for a while then it started to develop a hissing noise so i header wrapped the flex and it helped a little. when my headers went on, i found the precat that the cattman y pipe did not take off was leaking. the heat shield around it was completely black.
Old Aug 17, 2004 | 09:05 PM
Lontar1's Avatar
nop the car still stock. The engine sounds too crapy. It sounds like the Lumina (Chevy) f my dad. it sounds like it is doing like this.....gah,gah,gah,gah,gah. Try this quick.
Old Aug 18, 2004 | 08:09 AM
goldmaxNYC's Avatar
what year is your car?
could be a hole in the exaust? ..
i remember when my catalyst converter fell off on my old car. thing sounded like a freakin dragster.
Old Aug 18, 2004 | 09:15 AM
Lontar1's Avatar
nop the exhaust is ok......
Old Aug 19, 2004 | 01:11 PM
BP2K2Max's Avatar
can someone tell me where i can buy just the MAFS element and not the whole housing, i'm feeling a slight loss of power at 5K rpm and i think the mafs is on its way out again.
Old Aug 19, 2004 | 04:22 PM
RiN'sMAX's Avatar
the MAF for a 5'th gen is about 500 beans. I replaced one on my old infiniti, and now one on my 00 max that i bought last month. MAFs are a known problem as are the coil packs and the cylinder #1 spark plug well gasket. (hope you never need to know what it is). but i assure you it's a good whip......
Old Aug 19, 2004 | 04:23 PM
Lontar1's Avatar
Try Dave I got the phone number and the part number. It is at my office. I will post it tommorow...
Old Aug 19, 2004 | 04:32 PM
sloppymax's Avatar
the mafs for 2k2-k3 are more expensive but if you paid 500 for a 2k-k1, then you got ripped big time. i paid $85 for the maf sensor and tube brand new from jerry rome nissan. it took about 10 minutes to install the new maf. ive ordered from dave b before and hes got great prices and quick shipping as well. his number is 888-254-6060, ask for dave burnette.
Old Aug 20, 2004 | 08:47 AM
BP2K2Max's Avatar
awesome, thanks a lot.
Old Aug 20, 2004 | 08:51 AM
Bl_asd's Avatar
hey dude. WE HAVE SO MUCH IN COMMOM...My dad drives a Lumina too, WE ALSO LIVE IN ORLANDO...
QUOTE=Lontar1]nop the car still stock. The engine sounds too crapy. It sounds like the Lumina (Chevy) f my dad. it sounds like it is doing like this.....gah,gah,gah,gah,gah. Try this quick.[/QUOTE]
Old Aug 24, 2004 | 07:07 PM
ecko51's Avatar
I am having the same problem too. I have a 2k Auto w/ no mods and it sounds like there is no pipes running back from the motor. But only @ low idles. As soon as it goes over 2grand it sound normal.
It's at it's worst around 1500 rpm's
Have you found your problem or gotten any advise?
Old Aug 24, 2004 | 07:10 PM
Gennady7's Avatar
I got the same thing. THere is no leakage, its just the way the 2k sounds when you give low rpm.
I took it to the mechanic over this issue, he said it was fine, I should not pay any attention.
Old Aug 24, 2004 | 07:13 PM
irish44j's Avatar
retired moderator
guys...this is not the MAF making the noise. This is a leak somewhere in the exhaust - could be the gaskets between headers/ypipe/cat/catbak/muffler - anywhere. Bad MAF causes poor engine performance, but not loud noise.....
btw - you can get MAF assembly for 2k-2k1 for around $100 at any dealer. Here is the part:
also, make sure the tubing on your intake/airbox is securely tightened everywhere....if it's not tight to the throttle body, etc., you could be getting noise as well as poor engine performance (intake air leak)
Old Aug 24, 2004 | 07:50 PM
takkar's Avatar
i have the same noise but only when i step on it...at idle or when i drive slow, its fine...only when i punch on the gas do i feel a hissing noise from the engine area, which goes away as rpms drop
Old Aug 25, 2004 | 05:04 AM
sloppymax's Avatar
i really wouldnt rule out an exhaust leak. i had a hissing noise before my y pipe then it seemed to go away. then it came back, i wrapped the flex, checked as good as i could for leaks and nothing. then when the headers went on, we pulled the precat that the y pipe did not eliminate and the heatshield around it was completely black. precat was leaking letting all the buildup on the heatshield and causing the hissing.
-ReLLiK-
Apr 29, 2016 06:25 PM
BkGreen97
Apr 2, 2016 05:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
