Why is my car SLOW now?!?! Check for codes maybe???
Old Aug 17, 2004 | 10:25 PM
Kruppa's Avatar
my car is feeling real sluggish recently and I have two mods that are supposed to definitely help power ...PR CAI and y pipe so why does it feel like i'm accelerating much slower than before I did the mods
I have never checked for thrown codes and I have heard AutoZone can do this for free and pretty quick too is this true??? Maybe it could be somethin revealed by that and if not I think I should get it dyno'd to see what is really up and hopefully NE Dyno could tell me where the car is going wrong
I know it sounds bad but I would honestly rather have to replace something like the knock sensor and have a real reason as to why it feels slower bc its beginning to annoy me bigtime and sometimes i convince myself its just in my head, which it quite possibly could be...any input?
Old Aug 18, 2004 | 03:59 AM
Kruppa's Avatar
nobody has any ideas?
Old Aug 18, 2004 | 04:07 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
how many miles on your car.....?????
Old Aug 18, 2004 | 05:16 AM
Kruppa's Avatar
I have 50,000 miles on my car
My check engine light is not on, yet I have been told by people to still check for codes because I dont' feel the car is performing as it shoudl...AutoZone said they don't see how they could get a code if the light isn't on but they will try...could it still throw a code even tho the check engine light isn't on or is that a waste of my time?
Old Aug 18, 2004 | 07:40 AM
roar1's Avatar
It could possibly be your Mass Airflow Sensor. I had the same problem on my '00 GLE. The car just did'nt seem to have that old " get up and go ". At times I thought it was just in my head. It literally took 7 months before the SES light came on. ( It was a terrible 7 months ). Replaced the MAF and she ran as good as new.
Old Aug 18, 2004 | 07:47 AM
Kruppa's Avatar
how much is a new MAF???...and would a diagnostic at AutoZone detect it or do you think that i would most likely have to wait like you??
Ok well I can get a brand new MAF for $85...is it worth it to replace this not knowing this is the problem? i have 50,000 miles and have run out of other ideas as to what the problem may be...it's real easy to replace the MAF right???
Old Aug 18, 2004 | 08:02 AM
roar1's Avatar
You can try Autozone. I don't know if the computer will spit out a code WITHOUT a SES light on. The reason I knew that it was 7 mos. is because my particullar car was " Bang-shifting " into 2nd gear ( it is an automatic ) whenever I would nail it from a standstill. The new MAF cured BOTH problems !!
The MAF was replaced under warranty. I think the dealer said it would have cost me ~$300, which is ridiculus. I'm sure if you check around on this board you can do better. I feel for you. Driving a car with 225 HP that performs like it has 150 HP is NO FUN. Good Luck !!!
Old Aug 18, 2004 | 08:05 AM
Kruppa's Avatar
ok well for $85 i can do this...do you think that with 50,000 that could be the problem and even if it's not wouldn't it be a kind of good idea to replace it anyway? lol i think i just want a quick and easy solution to my problem....
it's easy to replace right it's right up on top of engine?
Old Aug 18, 2004 | 08:21 AM
Kruppa's Avatar
is there a way for autozone or somewhere to specifically test to see if the MAF is okay??
Old Aug 18, 2004 | 08:22 AM
I30swimmer's Avatar
go for it bro its like 6 bolts to take it off.. just like cleaning your throttle body.. just take it all off.. ( disconect battery) unplug that multitude of wires and replace thats my guess.. it cant be hard to do!!!
Old Aug 18, 2004 | 08:24 AM
I30swimmer's Avatar
maybe even try cleaning your throttle body first.. cheap to do like 3 bucks for a can of carborator cleaner.. ( i just got cheap spray stuff from autozone) and clean it out really good.. itll eliminate some hesitation.. and maybe thats what you got... i cleaned myn and the car ran so much better ..
Old Aug 18, 2004 | 08:37 AM
Kruppa's Avatar
anybody have a write up for cleaning the throttle body???
also does the knock sensor (if that's the problem) cause bad performance bc i heard that it has nothing to do with performance but i have no idea (nissan said that...yes i know they are retards but once again i don't know)
Old Aug 18, 2004 | 08:39 AM
roar1's Avatar
I noticed that you have changed your induction system. The MAF sensors on these cars R-E-A-L-L-Y don't like to see anything but a stock Nissan air filter.
IF you have $85 bucks and the time, you could change it yourself. The MAF is located on top and is relatively easy to get to. As I said earlier, mine didn't thro a code for 7 months. It's a gamble but might be worth a try. I would imagine that a Nissan dealer could POSSIBLY check the MAF specifically but would probably charge you $70.
Old Aug 18, 2004 | 08:45 AM
Kruppa's Avatar
Well would the new one (if i buy it) most likely go bad soon because of the CAI , cuz if thats the case then isn't it a waste of money??
Old Aug 18, 2004 | 08:51 AM
roar1's Avatar
I have a '00 GLE and a '02 GLE. I've had cam and crank angle sensors replaced.
I've had 02 sensors, MAF and ignition coils replaced. The ONLY thing that EVER affected the day to day performance of these vehicles was the MAF. FWIW.
Old Aug 18, 2004 | 08:55 AM
roar1's Avatar
Sorry, I wish I had a crystal ball.......but I don't.
Old Aug 18, 2004 | 08:56 AM
Kruppa's Avatar
ok but if i replace the one now with a new MAF my question is will it most likely go bad again because of my cold air intake or not necessarily???
Kruppa's Avatar
i could use a crystal ball right about now :-(
Old Aug 18, 2004 | 08:59 AM
I30swimmer's Avatar
clean the throttle body.. first
cheapest and pretty effective way of improving lost performance.. also.. just try tapping out your air filter, on the ground or somthing .. to get some of the dirt out of it.. or clean it
as for talking to the dealer.. dont bother.. they will just have you sit around.. then charge you and tell you nothing, itll be a waste of your time and money..
and you can always try as a last attempt, cleaning the MAF with electronic parts cleaner ( very shady ) i dont know if i would try it cause you may end up without a way to get to the dealer and buy a new MAF..
so... clean throttle body..... then clean air filter.. then replace MAF / or clean it ( i wouldnt)
Old Aug 18, 2004 | 09:03 AM
Kruppa's Avatar
i just cleaned my MonsterFlow Air Filter on my CAI about 2 weeks ago and replaced spark plugs last week
Old Aug 18, 2004 | 09:12 AM
Lontar1's Avatar
Get the MAF, I have an 01 and have the same problem , it feels with no power.... I'm going to buy the MAF soon from Dave for about $85 bucks..... also I'm going to replace the O2 sensors, have the lovely P0420 cose....... but don't have money right now.. the hurricane took my money with it..hehehhe
Old Aug 18, 2004 | 09:13 AM
2000GRNSE's Avatar
I'm having the same sluggish problems. Sounds identical (except I'm stock). I cleaned the throttle body and still have the same problem. Can you share with me where you found an MAF for $85?
It's time for new rotors and pads, too.
Old Aug 18, 2004 | 10:27 AM
Kruppa's Avatar
haha yah my neighbor owns a nissan dealership :-) that's how i get it for $85
and update....No Codes at Autozone so forget that idea of knock sensor
I got STP Complete Fuel Cleaner that does carburaters and fuel inj. and is supposed to restore lost acceleration and power so i'll try that
I also got STP Throttle Body cleaner that you spray into the opening of throttle body (i know this won't be as good as taking it out and cleaning it but i dont' know how to do that and it prob wont' help my problem from reading previous posts...if u think it will can u please post a how to if there is one???)
If these two things don't help at all then I'll get the new MAF (that is supposed to be updated according to the parts guy i always talk to)
Old Aug 18, 2004 | 10:39 AM
2000GRNSE's Avatar
Hey, tell your neighbor you need two, ya know, "just in case".
Keep us updated on your progress. Thanks.
Old Aug 18, 2004 | 10:43 AM
Kruppa's Avatar
2000GRNSE ...so you def don't suggest throttle body cleaning right ...i had heard it really does nothing but not bad to do it ...that's why i got the spray stuff where u can just keep it where it is and partially clean it i suppose just to say i did it haha
Old Aug 18, 2004 | 10:56 AM
TEEdotMAX's Avatar
hey bro i think im having the same problem. i dont think my max is performing as it should be... it might just be in my head. i bought a new MAF but i havn't put it in yet... i wanna beat down my current MAF before i swap them out. i'll let you know what happens when i replace it.
BTW, this might be a little off topic but... you should try replacing that monster flow air filter with a k&n cone filter. the k&n really changes the attitude of the CAI.
Old Aug 18, 2004 | 02:51 PM
Lytheum's Avatar
would a bad maf cause hesitation under WOT? sometimes when i floor my car it does nothing for like 5 seconds or so and then goes. it seems weird and is only under WOT. it sucks driving in traffic and not wanting to switch lanes in case my car decides not to accelerate.
Old Aug 18, 2004 | 04:34 PM
paralyse's Avatar
I Miss My Maxima
Possibly tanked your MAF when you "cleaned" your air filter. Intakes have been known to produce some loss in low end torque (accel) but should not be highly noticeable on Ye Olde Butt Dyno.
Computer might not set a code if the MAF is tanked.
Make sure you don't have any unmetered air entering the engine (loose gaskets or clamps on your CAI)
Why not do the easy thing first: put your old intake back on and recheck to see if the problem goes away?
Make sure you're running premium fuel, and have clean and properly gapped plugs.
Old Aug 18, 2004 | 06:33 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Make sure to have the ECU recalibrated for the updated MAF, I do this service here in IL, and I have a few spare MAFs for myself incase it goes bad. Your MAF is crapped out, no STP crap is going to fix your car, no injector cleaner or throttle body cleaning is going to fix it eighter. Install a new MAF, get the ECU reprogrammed with the newest program- which also takes care of the P0420 code that likes to come up on 00-01 Maximas.
Mike
Old Aug 18, 2004 | 06:37 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
maximas are ghey, they have their days
sometimes slow, sometimes insanely fast
Old Aug 18, 2004 | 08:18 PM
TEEdotMAX's Avatar
must be your max's time of the month
Old Aug 18, 2004 | 10:08 PM
Kruppa's Avatar
Ok, well once again here's the progress . . .
1. No codes thrown (Eliminates knock sensor, coils, etc)
2. STP Complete Fuel Cleaner
3. Cleaned Throttle Body
(Idles a bit smoother and maybe just maybe a little low end power back but it must be in my head)
4. Cleaned air filter last month
5. Synthetic Oil and filter change 3 weeks ago
6. New and correctly gapped spark plugs 2 weeks ago
7. Premium Fuel (93 octane) as usual
8. Checked connections on CAI and all seems fine...i highly doubt it has anything to do with that.
My Next Possible Steps
1. New MAF for $85 assuming that is the problem and taking the chance of wasting the money when it's not really needed. Also, what is this about reprogramming your ECU? I thought on our cars all you did was unplug the battery for a few hours to reset the ECU???
2. Suggestions...???
Old Aug 18, 2004 | 10:23 PM
kobalt's Avatar
Did you try resetting your ECU? All you have to do is disconnect the battery for an hour or so...I did it and the MAX felt way stronger...
Old Aug 18, 2004 | 10:27 PM
Lytheum's Avatar
i had my battery unhooked for about 2 hours today as i ran new cables for my radio. i hooked it back up and went over a friends and for some reason it felt as if it pulled harder. i thought it was in my head or something, but maybe it was off long enough to reset the ecu?
Old Aug 18, 2004 | 11:26 PM
MaximaPolak's Avatar
Kruppa....you should have told me because I had a 2001 MAF sensor when I came to the meet.....you could have had it!
Old Aug 19, 2004 | 07:22 AM
Kruppa's Avatar
Does anybody else actually think resetting the ECU will do anything???
and should i just buy the darn maf for like $80 haha
Old Aug 19, 2004 | 08:20 AM
TEEdotMAX's Avatar
yes new maf sounds good. i just put mine in today. overall, the throttle response has increased drastically. no sluggishness at all. my max is reborn!!!!
Old Aug 19, 2004 | 08:23 AM
2000GRNSE's Avatar
If you don't go ahead and by that dang MAF at least get it for me!
I'm gonna try to reset my ECU this afternoon. Sounds like we may have the same problem. If I get it figured out I'll let you know.
Old Aug 19, 2004 | 08:38 AM
friedbacon's Avatar
I have the exact problem. Mine is a stock 2000 maxima with 50k. I have trouble overtaking cars even at WOT. I've took it to the dealer and they can't find any codes. ARGH!
Old Aug 19, 2004 | 10:10 AM
Kruppa's Avatar
I just bought the MAF and have it sitting next to me at my desk lol i'm tryin to find a 10 mm socket to put it on while i'm at work...and i'm going to reset my ECU overnight :-) let's hope it works
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
lux97Max
19
Aug 27, 2015 07:48 PM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
