Changed climate control to blue, with a white screen.. PICS
Old Aug 18, 2004 | 07:52 PM
silvermax2k2's Avatar
just as the title says, all the buttons and **** are blue, and the screen is white. I also changed my clock to white, and the security light to ble as well. please post your comments, and check out my newly installed tv as well on my website! thanks!
-Chris
Old Aug 18, 2004 | 07:55 PM
Epacy's Avatar
Unsuccesful STL Coordinator
How did you achieve the blue? I much prefer blue. I was going to color the bulbs that shine down on the shifter.
Old Aug 18, 2004 | 07:56 PM
irish44j's Avatar
retired moderator
so what method did you use? Did you change the bulbs out or color them or what?
Old Aug 18, 2004 | 08:00 PM
Actually, i took out the factory bulbs, and they already had a blue "condom" on them, same with the light that shines down on the shifter. I replace the shifter light with a 5mm jumbo blue led, and used 3mm 6000mcd leds for the climate control.
please check out my website for more pictures on this.
webpage -----> http://www.cardomain.com/memberpage/479058/8
-Chris
Old Aug 18, 2004 | 08:50 PM
Pri63's Avatar
-Chris
damn how did you do the clock?? is it just an LED replacement because I couldn't find one when I did the security light in my 2k
Old Aug 18, 2004 | 10:08 PM
MIXXMAX's Avatar
Looks good! My A/C unit now has a few bulbs burned out on the one side. I was thinking of adding this blue theme like yours, but was skeptical of the lighting output. Are those bright spots from the LED output? What did you use to get the bright "white" LCD look? Also, maybe, while you had the A/C unit apart, you should have replaced the bulbs underneath the bottom of the unit with some of your LED's. Here are some pics of mine.
Old Aug 18, 2004 | 11:41 PM
danimsta's Avatar
where did u guys get ur leds from?
lsdiodes.com?
and did u use resistors?
looks nice
Old Aug 19, 2004 | 06:36 AM
Yeah, i already did that, but i didn't take clear shots of them. The TV was to bright for the camera to pick up the blue beam. but i did not do it the same way as you, like i said two/three posts ago, i replaced the light with a 5mm jumbo led, that works perfectly.
danimsta - got my leds off ebay... best ones you can get for the price. and yes... you need a resistor.
-Chris
Old Aug 19, 2004 | 07:38 AM
2k3TitaniumSe's Avatar
Looks hot. I should do that soon.
Old Aug 19, 2004 | 08:43 AM
HitmanAngel2k3's Avatar
looks sweet what number of LEDs did you get? how many? I'm tryin to do that right now? so far just the clock is white getting there
Old Aug 19, 2004 | 10:01 AM
I just noticed that the hole for your tv monitor isn't straight. Looks a bit weird.
Old Aug 19, 2004 | 10:26 AM
it is pretty much straight, but not completely. the pictures make it look worse then it is. when i did the tv, i had no previous knowledge on how to do stuff like that, and it was my first time. i did the best i could, and i do not think it came out bad at all for a first timer.
maybe if i feel like it down the road, i will try again, but there was so much work involved that i really never even want to look at the stuff again... not to mention it took up my entire vacation time to finish it.
thanks for pointing out my flaw..
-Chris
Old Aug 19, 2004 | 10:30 AM
stevay's Avatar
oh yeah chris. what'd you do w/the hazards button did you just get rid of it? and the 12V lighter thing. thats no biggie though
Old Aug 19, 2004 | 10:31 AM
what number of led's did i get? i am not sure what you mean... led's do not have part numbers, but if you mean the specs, then they are 6000mcd. you need 3 of them. very easy to do!
-chris
Old Aug 19, 2004 | 10:47 AM
Well, the funny thing about the hazzard button is, if you unplug your hazzard button, your directionals will not work! so i had to leave it connected and tuck it into the back. i completly removed the cig lighter. i really didn't care about that, i never used it... and i broke it when i took it out. lol. and i did lose my change holder, which i miss out of everything. o well, it was a loss i am willing to take.
Old Aug 20, 2004 | 11:52 AM
no, the lcd does not use a bulb. LCD = liquid crystal display. all you have to do is tape on a peice of a deep red celophane onto the display. red and green = white.
-Chris
Old Oct 10, 2004 | 04:56 PM
pvaudo's Avatar
I was hopeful there for a second that you found a way to make the clock brighter, but more tint means it must be slightly darker. Oh well, time to cut the cable!
Old Oct 10, 2004 | 11:52 PM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
Looks awesome, but i just seems like waaaay too much work for me!
Old Oct 11, 2004 | 01:14 AM
Omegasrk's Avatar
I can't tell from your pictures, but what size resistors did you use. Also, where did you soldier those resistors at? I was about to do the same thing with my climate control since one of my bulbs is burned out and change all 3 of them to blue leds. BTW, your setup looks great.
Old Oct 11, 2004 | 08:05 AM
xTeCaOx's Avatar
so how were you able to change the climate and clock to WHITE??
Old Oct 11, 2004 | 08:58 AM
PearlWhtMaX2000's Avatar
Chris, how long did the process take?
Old Oct 11, 2004 | 10:17 AM
Bl_asd's Avatar
i did the blue led on my A/C too, they work nice. I just got a very very very importyant question, WHERE DID YOU GUYS GET THOSE CELLOPHANE??? i tried everywhere, even gift store. I'll do led swap on my radio this weekend along with gauge. I don't have digital cemara thou..anyone who lives in central FL wants to do it together?
Old Oct 11, 2004 | 08:02 PM
Whoa, this thread came back from the dead. lol.
well, to answer questions, the resistors vary from leds, but normally if you stick with 330 ohm, you will be good. you solder them to the positive leg of the led.
it took me about 2 hours to do the climate control, and about 10 mins to do the clock.
BL ASD - man... you have so many questions!!!! lol if you can't find any of the stuff, then i will mail you some. just paypal me what you think my services are worth. lol.
-chris
Old Oct 11, 2004 | 08:12 PM
Bl_asd's Avatar
lol....hey..good students always have tons of questions. i'm sorry..seriously..where did you get cellophane?.. i spent a day drove around from home depot wal-mart, k mart gift stores..didn't find any.. and the funny thing is that when i ask those ppl "do you guys sell cellophane?" they always say "what's that?" DUH
Bl_asd's Avatar
how's your car, Blkmax95c? everything ok now?
Old Oct 11, 2004 | 09:10 PM
Well, I will just send you some of mine. PM me with your addy, and i will get it out this week for you.
as far as my car... it wasn't a big accident, but i am no longer happy with my car. I am thinking about just selling it after i get it fixed, sell all my mods, and just get a G35. I wouldn't be paying too much more then i am paying now. just thinking about it... not anything set in stone right now.
-chris
Old Oct 11, 2004 | 09:39 PM
Cheezwiz's Avatar
Wow, GLARE! Not cool.
Old Oct 11, 2004 | 09:52 PM
WOW, A dumbass! Not cool.
learn how to post something that is constructive.
Old Oct 11, 2004 | 11:53 PM
K Pazzo 6's Avatar
very nice....
p.s. so why do u have 01 rims on a 02 max?
Old Oct 12, 2004 | 08:30 AM
Originally Posted by K Pazzo 6
very nice....
im damed if i do, and damed if i don't.
I'll tell you what, if you trade me your rims for mine, i'll tell you why.
Old Oct 12, 2004 | 11:53 AM
aliti19's Avatar
hahahaha
Take it easy on the
Old Oct 12, 2004 | 12:26 PM
maseo77's Avatar
How do u remove the shifter lights to change them out?
Old Oct 13, 2004 | 05:06 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You need to remove the climate control unit, there is a bulb located underneath of the circutboard housing that shines on the shifter.
Old Oct 14, 2004 | 06:40 AM
custommaximaSE's Avatar
-Chris
Hey dude since you are the color expert (don't take it the wrong way ),I'm trying to do something here.
You said red + green =white.
Now the question is what color i need to mix with the blue to get white.
>>>>>>>>> ? + blue =white.
BTW,clear some of your PM i can't PM you.
Old Oct 14, 2004 | 08:25 AM
>>>>>>>>> ? + blue =white.
What has a blue lcd in your car that you want to turn white? i will have to do some research to see if you can do that or not.
sorry about my full pm box, but i get 5-20 pm's a day from you guys about all these lighting questions, and the mods i have done to my car. ahh!!! lol. sometimes i just forget to clear it out. (sometimes on purpose!) lol.. j/k.
but i will try to figure it out for you and get back to you.
Old Oct 14, 2004 | 08:48 AM
Thanks for your time.
Could you please tell me where did you get the red cellophane?Is it something like this:
I asked you what color to mix with the blue color to get white ,like (? cellophane + blue =white).
I'm doing the gauge culster white ,so im thinking if i mix (?) color with the blue it will turn it in to white.
Old Oct 14, 2004 | 08:55 AM
yep, thats the stuff. make sure you get it in dark red... no pink.
also, that will not work on you gauges. do not even attempt it.
-chris
MikesChevelle
Mar 2, 2021 11:32 AM
homeyclaus
Sep 3, 2015 06:15 PM
asianstyle
Aug 24, 2015 08:29 PM
