15,000 mile service - needed or not?
Old Aug 18, 2004 | 09:51 PM
LithiuMax
I'm a bit past 15k miles now, and the service book lists a bunch of stuff to do. What should I have done that is a must?
Old Aug 18, 2004 | 09:57 PM
chinaonnitrous1's Avatar
hmmm.....flush tranny fluid and put some synthetic in..... oil change, filter change, clean throttle body out with some cleaner, use some chevron fuel system cleaner. To early to change fuel filter, nothing really to maintain.
Old Aug 18, 2004 | 10:42 PM
LithiuMax
I had an oil change ~1,500 miles ago. Where can I get a tranny flushed and refilled for relatively cheap? I don't want to mess with cleaning the TB - too many failed MAFs from that, as I've read on here.
Old Aug 18, 2004 | 10:45 PM
turbo95max =) he carrys redline tranny fluid. =)
Maximadmoiselle's Avatar
Tranny flush at 15k? If anything, I'd do a change every 20-30k or so, but there's no need to flush it at 15k. Of course you can if you need to. A tranny fluid change should be around $50, but a flush would be significantly more.
Old Aug 18, 2004 | 10:46 PM
TB is fine to clean....its the MAF sensor. TB is where your intake ends and your intake manifold begines.
Old Aug 18, 2004 | 10:47 PM
LithiuMax
I know what it is... It's just that people who have cleaned it have complained about failed MAFs soon thereafter.
If I flush the tranny soon, I'll holler at Matt..
Old Aug 18, 2004 | 10:49 PM
thats bs......thoes two parts are like totally independent. i dont belive it. *shrug* ive taken my intake maniflold off several times and its spotless, just increased performance.
Old Aug 18, 2004 | 10:51 PM
LithiuMax
I'll search some threads to see what exactly was said, but I'mm 99% sure people were blaming the TB cleaning for their failed MAFs, and others were agreeing.
Old Aug 19, 2004 | 12:50 PM
LithiuMax
Anything else I should take care of?
Old Aug 19, 2004 | 12:54 PM
kcowden's Avatar
You've taken off the entire manifold and cleaned it, or you took it off and it was still "spotless"??? If the first is true what did you clean it with? Thanks.
CorollaULEV
30
Aug 9, 2021 08:11 PM
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
Samedi
Aug 13, 2015 04:05 PM
Flores94
Aug 11, 2015 12:53 PM
