what should next mod be
okay here is what i have done: i have a cosmo racing cai, warpspeed y-pipe, arospeed udp, 2" lowering springs, halo headlights, clear with black housing tailights, strut tower brace, and a whole lotta stereo junk. just wanted to get some opinions and direction on where i should go next performance wise. i have limited cash flow because im currently in school. if anyone could help out it would be greatly appreciated.
fidanza flywheel with a ACT or Spec clutch. Advance ignition timing via the ECU 3 deg, repleace the MAF and recalibrate the ECU to the new MAF program. Exhaust don't really do much in terms of power, if you want a nice not raspy sound- look for a dual tip REAL Remus muffler and have a shop make ya a 2.5" from cat back exhaust system with the Remus rear. Make sure to get a Resonator, something around 16"-20" long and about 5-6" in diameter- Magnaflow makes nice ones. Forget HS headers, get some Cattman headers.
How do you advance ignition timing via ecu 3 degrees?
Which MAF would I need and how would I recalibrate the ECU afterwards?
Lastly, does cattman or hotshot make headers that will mate with the warpspeed y-pipe?
I have a 2000 maxima gxe 5spd with GAB/OSCAI, y-pipe, 2.25" custom exhaust with no resonator, and udp, and in the same boat of figuring out what mods to do next. Looking towards low 14's down the 1/4mile.
Putting a flywheel and clutch into a 5th gen takes about a hour- 2 hours tops ! You have to remove the transmission ofcourse. In order to recalibrate the ECU or advance the timing you need to have a Nissan Consult II scan tool. I have every bolt on possible on my 01 GXE short of cams ( for now) and you can get away with 3 deg of ignition timing- 4 deg is max, but since its summer time I don't wanna risk detonation. Using 93 octane gas is a must then. Stock ECU runs pretty rich at 4K RPM and up under WOT, I found out I was at 10.8:1 at 5K RPMs andthen when VIAS opened up at 5200RPM I went up to 11.4:1. I have since corrected those figures and found a fat chunk of power hidden inside the stock ECUs fuel map. I'm still waiting for TechnoSquare to beat my own S-AFCII maps. I still want the higher redline of the TS ECU, but god knows when if EVER will it be ready for us DE-K drivers.
please write back soon, im in desperate need of some horsepower.....heh heh heh
you need to go to Engine, Ignition timing, and then go advance - you can go up to 4 deg advance. But with the current weather I wouldn't do more than 3. I live on some flat lands but the heat gets pretty high sometimes so I chose not to ping like crazy with the more advanced timing. For winter I will go all the way up - 4 deg Advance, currently I run 3 Deg, along with the new MAF calibration software I gained 10WHP all accross the board. Timing alone has given me 6WHP increase at 4K RPM vs stock timing when I 1st got my car- 206WHP with just a POP charger and 3 deg advance. This also works on 3.5Ls.
to clariffy what I just wrote- I was hunting for where I lost HP after a MAF repleacement with a new one, and did a ECU recalibration via Consult II, redynoed and noticed 10WHP gain from 2500-4600RPM, then it leveled off to like 6WHP and at 6800RPM I was 12WHP higher than I used to be. I compared my MAF voltage readings in between the 2 runs via Consult and MAF reading has been highest ever so far
I really wanna try cams but right now I am inline for a turbo Ypipe.... cams cost around 1000 bux, and you need a whole day pretty much to install them. Where piecing up my own turbo kit wont cost me more than 3K bux and the gains will be substantial with a HKS GT35R that is in my trunk right now.
zzznightmarezz
Sep 21, 2015 06:32 PM
