Car idles at around 600 rpms, problem or no?
Old Aug 21, 2004 | 09:53 PM
SE01's Avatar
I've noticed that my car sometimes idles at around 600-650 rpms. Is this normal or is my throttle body dirty? I'm hopefully installing a Berk Intake soon, would it be worth it to give the TB a wipe-down in the process?
Old Aug 21, 2004 | 10:32 PM
FanaticMadMax's Avatar
That sounds about right, mine idle around 600rpm. There's nothing wrong unless it's nearing 1k if you just had a cold start up.
Old Aug 22, 2004 | 03:18 AM
Maximadmoiselle's Avatar
OT, should there be any difference between the RPM the 3.0 and 3.5 idle at? I was told that a 3.5 idles at ~500, whereas mine personally idles at ~6-700.
Old Aug 22, 2004 | 08:30 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
autos & manuals idle at different rpms. manuals are typically lower.
Old Aug 22, 2004 | 10:42 AM
BlackBIRDVQ's Avatar
drag racing is for wussies
Mine idles at 850 and its a manual, I have Place Racing motor mounts so anything below 700 makes alot of things shake and squeak. Manuals always idle higher than autos. Torque converter pump creates too much pressure at higher RPMs and this will cause the tranny to wear quicker cause of higher ATF temperatures. Too low of a idle causes wear on the engine from what its called "lugging" the engine. Engine has very little power at idle, so in order to keep runing ECU has to try to compensate for it not to die out. Alot of times you get detonation and preignition from too low of a idle. There should be a sticker under the hood with whats the recomended idle speed for both auto and manual- but since I have a CF hood I can't tell ya what it is. I know on my Infiniti or my 00 Altima there are stickers under the hood with the specified idle and valve adjustment specifications.
Old Aug 22, 2004 | 12:30 PM
scopium
if u are all stock you will idle at 500-700
if u have a y pipe usually idle at 800-1000 thats what mine idles at .. i have intake, y pipe and catback
Old Aug 22, 2004 | 12:35 PM
MCE's Avatar
MCE
My 01 manual idles 600 R.P.M. smooth.
Old Aug 22, 2004 | 01:07 PM
SE01's Avatar
I have a manual. I guess I'm all set then, but thats for everyones advise.
Old Aug 22, 2004 | 04:38 PM
sloppymax's Avatar
thats what ive seen every other maxima manual idle at. between 6-650. my 2k1 auto idles between 713-725 according to consult 2 & my obd software.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
JMag90
Aug 25, 2015 09:17 AM
Maxboy23
Aug 11, 2015 11:59 AM
