Traction control
Old Aug 22, 2004 | 11:39 PM
Whtmax'01's Avatar
Traction control
Anyone know how the traction control works in the 2000-2001 maximas. I heard that when wheels are slipping , computer turns off some of the cylinders.
I noticed that when it is turned off car accelerates much better without any lag in power. Also is there a permanent way to turn off this system completly w out having that tcs light lit in the dash?
Old Dec 10, 2004 | 05:53 AM
ZeRo MaX's Avatar
I would also like to know.. i'm guessing a fuse?
Old Dec 10, 2004 | 08:09 AM
upstatemax's Avatar
you could just turn it off everytime you get in the car and disconect the light behind the dash...
Old Dec 10, 2004 | 10:16 AM
njmaxseltd's Avatar
TCS only activates when wheel spin is detected. Your engine does not perform any differently with it off. When wheel spin is detected the engine throttles down until grip is established, then the engine is returned to normal power, if wheel spin is detected again, the process repeats.
Old Dec 10, 2004 | 01:20 PM
ZeRo MaX's Avatar
So you're sayin... I should just leave it on.. and i wouldn't have to worry about it if i wanna go WOT on my car?
Old Dec 10, 2004 | 03:58 PM
Matt_01SE_20th's Avatar
doesnt the TCS operate on the ABS system?
Old Dec 10, 2004 | 09:14 PM
Lytheum's Avatar
only time it should hurt wot performance is from a dead stop. it will keep the tires from spinning when you lay into it.
Old Dec 11, 2004 | 03:48 AM
jmal's Avatar
Thats what I thought....when wheel spin is detected, the brakes are applied to the spinning wheel...no?
Either way, with my TCS off I can only get a good chirp from a dead stop on dry tar... ....I wonder what headers/intake/cat-back would do to fix that.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
