Xtec foglight 6000K HIDs installed! *PICS*
Old Aug 24, 2004 | 09:46 PM
  #41
umnitza's Avatar
Former Sponsor
Originally Posted by MacAlert
Because yellow light is more "visible."
Are you sure about that?
Old Aug 25, 2004 | 07:19 AM
  #42
MacAlert's Avatar
In the rain, yes.
Old Aug 25, 2004 | 07:48 AM
  #43
HitManSE's Avatar
In the rain, yes.
Not only in the rain, but overall they are more visible. The color yellow is the 2nd most eye catcing color there is next ro red. Im not saying we should all go out and get yellow HID's though
Old Aug 25, 2004 | 08:24 AM
  #44
SilverSleeper's Avatar
Did we ever find out the cost? Is it a bulb and/or housing replacement? Any rewiring involved?
Old Aug 25, 2004 | 09:10 AM
  #45
umnitza's Avatar
Former Sponsor
The sun is 5500K or thereabouts
Old Aug 25, 2004 | 11:33 AM
  #46
MaximaPolak's Avatar
SEXY
Old Aug 25, 2004 | 11:48 AM
  #47
Igor911's Avatar
Guys, just an FYI
Imagine the light output X 2 of what you see in the pics. HID fogs are amazing in person.
Old Aug 25, 2004 | 12:14 PM
  #48
LithiuMax
Originally Posted by Igor911
Guys, just an FYI
So true...
Old Aug 25, 2004 | 12:23 PM
  #49
HNDA ETR's Avatar
Still Here... IM me for more..
i can't wait to get mine....
5000K HID Fogs....
Old Aug 25, 2004 | 12:28 PM
  #50
Pearltt's Avatar
How much is a set going for???
Old Aug 25, 2004 | 12:39 PM
  #51
LithiuMax
$325 shipped to your door.
Old Aug 25, 2004 | 12:55 PM
  #52
Melvin_03SE's Avatar
I'll probably be interested in this mid to late next month... Even if it's still not the same price.
Looks awesome!
Old Aug 25, 2004 | 07:01 PM
  #53
redstradic's Avatar
Some details -
Total install time with removal of headlights = 10 minutes per side.
Total output = 2400-2600 lumens
Total modifications = 1 (bending internal shield with flat screw driver to fit bulb)
Total wire splices = 0
so it sounds like there is no having to deal with any wiring at all. you basically put the bulb in and have to bend the internal shield. can the stock wiring withstand the heat that the bulb puts out? also, is there any difference in the bulbs or modifcations needed since the 00-01 fogs are different than the 02-03 fogs? thanks.
Old Aug 25, 2004 | 07:43 PM
  #54
umnitza's Avatar
Former Sponsor
yes, stock can withstand easily.
00-01 fogs, no idea, but probably the same.
Old Aug 26, 2004 | 07:19 PM
  #55
LithiuMax
Looks awesome!
Thanks, and welcome to the org.
Old Aug 26, 2004 | 07:39 PM
  #56
skalberti's Avatar
I live life on the edge
You copy cat
DITTO I know IGOR I copied off of you. On a postive note.... things are looking brighter around here. When will the others see the light?
Old Aug 26, 2004 | 07:53 PM
  #57
ZIPPIN's Avatar
Mauja He Mauja
i want these bad need to save some muaaaaaaaa
Old Aug 26, 2004 | 09:19 PM
  #58
No, thank you!
Old Aug 26, 2004 | 11:13 PM
  #59
GoldenMax02's Avatar
I'm interested in a pair of those 6000k's.
Old Aug 26, 2004 | 11:37 PM
  #60
LithiuMax
For the guys that have these: how did you aim your fogs, or did you re-adjust them at all? My fogs shine bright and fairly far, but I want them to show more road.
Old Aug 27, 2004 | 05:42 AM
  #61
ZIPPIN's Avatar
Mauja He Mauja
http://www.autooptiks.com/aiming.html
Old Aug 27, 2004 | 12:51 PM
  #62
LithiuMax
Originally Posted by dba1999us
Nice.. thanks much.
Old Aug 27, 2004 | 12:54 PM
  #63
umnitza's Avatar
Former Sponsor
Guys we have very few left, but can order more
Old Aug 27, 2004 | 01:02 PM
  #64
Igor911's Avatar
Does this kit come with a Ballast, Starter and bulb? Just like all other HID kits?
Old Aug 27, 2004 | 01:03 PM
  #65
LithiuMax
Of course...
Old Aug 27, 2004 | 01:07 PM
  #66
umnitza's Avatar
Former Sponsor
There is NO need for a starter, it's all built in
Old Aug 27, 2004 | 01:14 PM
  #67
Igor911's Avatar
Of course...
OK? Then how can Matt say:
Some details -
I have installed 2 sets of HID fogs and 2 sets of headlight HID's. The fogs take about 1/2 day to do. (4-6 hrs)
10 min per side will take you just to remove a headlight to get down to the fog screws.
Not only that, you need time to mount the starters like so:
That alone takes about 15-30 min a side since you need to pre-drill then screw.
Next you need to mount the ballasts like so:
Once again, pre-drill and then screw them in. Takes 15-30 min.
Then you need to drill the fog light cap. There needs to be a 1" hole so the wires can pass. Then the reflector needs to be pushed in further so the HID capsul can fit without rubbing. Then you need to silicon the open space so that there will be no condensation in the fog and then adding a layer of tape won't hurt. Like so:
That process alone takes hours to do since you need time for the silicon to dry.
Once that is finished, you need time to connect all of the wires, upgrade the foglight fuse and then aim the fogs so they dont kill ppl from the glare. Then reinstall everything (headlights, foglights, ect.)
This job is far from 10 mins.
Old Aug 27, 2004 | 01:17 PM
  #68
Igor911's Avatar
then subtract time for the starters from my post. I just don't want ppl getting the wrong impression of this install. It's not that simple.
Old Aug 27, 2004 | 01:30 PM
  #69
LithiuMax
Matt and I installed mine in roughly 20 mins.
Old Aug 27, 2004 | 02:03 PM
  #70
Igor911's Avatar
Right, by using duct tape...
Old Aug 27, 2004 | 02:05 PM
  #71
Are there any pics of the acutal kit outside of the car? Perhaps still in the box?
Old Aug 27, 2004 | 02:28 PM
  #72
LithiuMax
Uh.. did I say ductape? Double sided tape was used for the ballasts (provided with the kit) and the wires that were not used are taped up with electrical tape.
Old Aug 28, 2004 | 11:09 AM
  #73
skalberti's Avatar
Your right IGOR, I spent about 4 hours total. However, I didn't have to bend anything in my housing and didn't have to re aim my fogs. I have no problems with glare or getting flashed by oncomers. They had the same beam pattern as the stock ones. I guess there's a quick easy way and the there's a right dependable way
Old Aug 28, 2004 | 11:22 AM
  #74
Ryans Maxima's Avatar
All I can say is wow - these things look awesome. Really clear and beautiful to the naked eye. The camera takes some of the gorgeous qualities of the 6000K HID away, but you can still see how great they look. Should have used a tripod
Thanks to Matt from Umnitza for this sweet product...
Here are the pics.. more in the next post.
Hey, the last pic in this set, do you JUST have the fogs on, or both fogs and headlights? Cuz if thats just the fogs, thats amazing
Old Aug 28, 2004 | 12:39 PM
  #75
Igor911's Avatar
So much for 10 mins a side
Old Aug 28, 2004 | 01:06 PM
  #76
LithiuMax
Only the foglights are lit up in that pic (the angel eyes as well, but they don't put any light on the ground).
Old Aug 28, 2004 | 01:09 PM
  #77
LithiuMax
What Matt and I did wasn't dependable? Matt pretty much made all the connection, and I helped out a bit. It took ~10 mins a side. Everything works. No loose wires. No loose connections. No rattling, no drilling, no sparks, no flickering. Please tell me how my install is different from yours. I don't think a person offering a 5 year warranty on their product would put together a half-assed install right in front of a customer/friend.
Old Aug 28, 2004 | 01:11 PM
  #78
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
i want em too...these just bulbs, or is this a true hid kit? sorry if a stupid question.
Old Aug 28, 2004 | 01:20 PM
  #79
LithiuMax
Originally Posted by IWNTMORHP!!
i want em too...these just balbs, or is this a true hid kit? sorry if a stupid question.
It's not Hyper White bulbs or anything like that - those are crappy and burn out in 6 months.
This is a true HID kit - bulbs, ballasts, and harnesses.
Old Aug 29, 2004 | 10:24 AM
  #80
skalberti's Avatar
I was wondering, did you keep the factory caps that cover the bulb or did you just remove them completely? If you kept them there is no way to keep from drilling them and running the new wires threw them to get a good water tight seal. IF you didn't condensation will show shortly
