Can we make this intake from an Altima work?
Old Aug 25, 2004 | 10:36 PM
MAXINXS's Avatar
This picture clearly shows the "air scoop" on the Altima moves air directly into the intakes path. Has anyone tried to fit this on a Maxima? I'm sure the gains would be minimal if anything, but every bit helps. I wonder if all you would need to do is drill holes in the front support brace and put those 4 little clips in.
Old Aug 25, 2004 | 10:41 PM
MAXINXS's Avatar
After looking at this pic of my car, I realize the battery is in the way. Should have checked that first.
Old Aug 26, 2004 | 08:59 AM
white m3 guy's Avatar
you can move the battery sideways,
Old Aug 26, 2004 | 09:04 AM
panda_1's Avatar
i doubt you would really see any diff, it would be a better idea if you could run a scoop from a place that can run more and cooler air.
Old Aug 26, 2004 | 09:05 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
That's true just move the battery sideways and ther you go.......
Old Aug 26, 2004 | 09:08 AM
Lontar1's Avatar
I think you can add a hose a big one from under the car and make it look like a Cold Air intake or something. Cosmetic... I don't think so but it will work...
Old Aug 26, 2004 | 09:30 AM
scopium
the reason why we have out intakes behind the batter is to provide some kind of heat shiel "heat shield"
if u move your filter by the air scoop .. your gonna get engine air .. very hot..
i think the altima intake is well made
Old Aug 26, 2004 | 10:09 AM
takkar's Avatar
funny you should mention that the altima intake is made well
I made it..no seriously..Anytime you get the chance..look for a ABC(in an oval) symbol on the intake..thats the name of the company that i worked for when i designed it.
Also you cant move it over since there is a resonator dangling beneath the airintake
MikesChevelle
Nov 23, 2024 11:17 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Max8
Aug 20, 2015 07:20 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kenc15
Aug 5, 2015 08:29 AM
