Excessive Interior Noise
Old Aug 26, 2004 | 12:40 PM
DivaLMaxa's Avatar
I have a 2k GXE and no matter what tires I run, the noise is from the tires is too loud. I began really noticing this after the first set of replacement tires...it's didn't seem to be too loud with the original tires but maybe I just didn't notice then. My question is there something I can put in the wheel wells to deaden the sound or can someone suggest the best tires that don't compromise handling. Thanks.
DivaLMaxa
2k Icelandic Pearl
92K miles
Old Aug 26, 2004 | 01:53 PM
burnout's Avatar
Alignment
DivaLMaxa
2k Icelandic Pearl
92K miles
Have you had the car aligned? I noticed a more of tire/road noise when I had lowering springs (no alignment after springs). I have recently raised the car back to stock and the excessive road noise from the tires magically went away. Could be a number things, though. BTW, I have noticed that Maximas seem to transmit more road noise and general vibrations back to the driver than other cars in this catagory.
Old Aug 26, 2004 | 05:31 PM
irish44j's Avatar
retired moderator
yep, it's not just you...we have a noisy car...oh well. as long as the engine and bose drown out the road noise....
but here's one thing I did to help deaden road noise:
http://forums.maxima.org/showthread.php?t=330008
Old Aug 27, 2004 | 09:20 AM
CVicVogel's Avatar
You can try to spray some GOOD undercoating in the wheel wells and anywhere where painted metal shows in the unibody.
Be careful NOT to cover up any drainage holes or hoses used to drain the air conditioner.
Check that your window seals are aligned properly...especially the troublesome quarter window in the rear doors.
thanks
Old Aug 27, 2004 | 10:24 AM
jgibson146's Avatar
Try some sound deadening in the doors especially the rear doors.
Old Aug 27, 2004 | 09:39 PM
Rizzob's Avatar
I can't stand the noise either man. Thats why I'm trying liquid deadener on the doors and extra foam material on the door trim panels. The deadener is on the doors already, but the panels are still off. Believe me, after a couple weeks of driving around with no panels, I can say they absorb a significant amount of noise when in place.
The tire whine thats so annoying is mostly high frequency noise. Thats why I was thinking some type of foam in right places might make a difference.
Old Aug 28, 2004 | 12:22 PM
-Red-'s Avatar
Have someone take a look at the bearings, a lot of people seem to mistake the drone with either something produced by exhaust or tires. I had the same problem in my car, dealer finally ended up replacing the bearings and the noise was gone.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
uttadms31
Sep 30, 2015 05:24 AM
