2002 SE tail lights to 2001 SE tail lights does it work?
Old Aug 27, 2004 | 11:06 PM
sleotta's Avatar
i want the black 2001 SE tails for my 2002 SE with the chrome tail lights...
is there rewiring envolved?
has anyone done this before?
tips?
Old Aug 27, 2004 | 11:23 PM
steaLthyMax's Avatar
i just finished doing this and as far as i can see there is no problem. I havent actually installed the lights yet, just hooked up the wiring from the stock 02 SE to the new 01 SE taillights and they work fine.
Old Aug 28, 2004 | 12:55 AM
foodmanry's Avatar
Da Roller Coaster!
Plug and play.....
Old Aug 28, 2004 | 01:28 AM
vqman
some guys said in this thread that they had some trouble
http://forums.maxima.org/showthread.php?t=333137
-vq
Old Aug 28, 2004 | 01:57 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
I did the swap w/ another org member. There will be PLENTY of people (00-01) that would love to swap their tails for yours in your area.
Make sure you swap the harnesses out together w/ the taillights.
Also heat up the silicone around the tails w/ a heat gun/blow dryer before prying them out. It'll make your life a lot easier.
If you have any more questions, fire away!
Old Aug 28, 2004 | 11:45 AM
xTeCaOx's Avatar
i'll trade with you if you want...but im in florida
Old Aug 29, 2004 | 08:24 AM
sleotta's Avatar
so basically if i pick up a pair of 2k1 lights i need to take the bulb harness also, then do some rewiring.... correct?
Old Aug 29, 2004 | 10:15 AM
you just need to make sure you have the bulb harness that comes with the 01s..no rewiring will be needed if you have the harness that comes with it
Old Aug 29, 2004 | 03:31 PM
aliti19's Avatar
Si.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
fastcarny
Aug 12, 2015 03:50 PM
kenc15
Aug 5, 2015 08:29 AM
yat70458
Aug 3, 2015 01:16 PM
