wheel spacers????????
Old Aug 29, 2004 | 08:09 AM
PearlWhtMaX2000's Avatar
ok im am getting a new set of rims (finally) but i want them to be flush w/the fender and side of the car, i need wheel spacers for that right? the rims are 19X8 and 35 mm offset. what kind off spacers do i get? where do i get them? and how much would they run me?
Thanx alot
Old Aug 29, 2004 | 08:40 AM
redstradic's Avatar
with that size wheel and with that offset you wont need any spacers. the only thing you would possibly need spacers for, is for getting on the center cap of the wheels. just go with a 245 series tire and you will be set.
Old Aug 29, 2004 | 09:00 AM
soundmike's Avatar
Very sound, Mike
I have 17x8's with the same offset, though the fronts are flushed the back could definitely use spacers. I'm thinking another 15mm will probably work.
Old Aug 29, 2004 | 09:14 AM
ZIPPIN's Avatar
Mauja He Mauja
this is for a 20mm spacer
http://home.insightbb.com/~davidwhon...cer/spacer.htm
Old Aug 29, 2004 | 10:00 AM
so how many mm would i ned? and how much do they go for? the tires are on the rims already, they are 245/40/19.
thanx
Old Aug 29, 2004 | 12:01 PM
goldmaxNYC's Avatar
i believe 15mm should do it. i got 18x8 with 245/40/18
but after speaking to my mechanic .. he strongly disapproves of spacers more then 5 mm. ( from his experience he said he seen wheels falling off). i trusted his oppinion and i got 5mm just to clear the center cap of the rim... we'll see how it goes
Old Aug 29, 2004 | 12:52 PM
hmmmmmm i dont know what i should do. i think im ganna go with the 15 mm would 20mm be too much? and how much do these go for?
Old Aug 29, 2004 | 01:55 PM
Hamy's Avatar
I was running 19x8 with a 30mm rear offset and I think I could have still gone another few degrees. I'd say get a 10mm and drop the over all offset down to 20mm. That should look just right. Make sure you get H&R spacers and REPLACE THE STUDS!! I can't stress how crazy it is to drive with spacers and stock studs. Your wheels could just fall the hell off.
Old Aug 29, 2004 | 02:37 PM
i dont know much about htis stuff, so how do i drop the off set?? and where do i getr the spacers, and studs? and how much?
Thanx
Old Aug 29, 2004 | 03:16 PM
ZIPPIN's Avatar
Mauja He Mauja
i am going to get the 20mm for EVO-5's 18"
http://www.importstreetscenes.com/su...h&r/index.html
http://www.performancenissanparts.co...roducts_id=385
http://optionimports.com/3065662a.html
Old Aug 29, 2004 | 03:56 PM
MyownNismo's Avatar
Future Camaro SS owner
I got 19x8 with 35mm I am going to use 5 mm spacers for rear but haven't put them on yet.
Old Aug 29, 2004 | 04:22 PM
maximadave's Avatar
detailerdaveb@gmail.com
I'd like to get 5mm wheel spacers for the rear but I've noticed the right rear tire seems to rub a little bit if there is a big dip in the road. The left rear seems to be toe'd in a bit and does not rub. I dunno what to do
Old Aug 29, 2004 | 05:03 PM
soundmike's Avatar
Very sound, Mike
Maybe something got bent?
Old Aug 30, 2004 | 07:02 AM
rule da road's Avatar
i'm goin with 1/2" which is about 13mm on my stock rims and 235 tires. In NY we wont pass inspection if it sticks out at all pass the fender, and since it might rub like above anyway it should work. Ebay of course, wheel-centric.
Old Aug 30, 2004 | 07:54 AM
so u guys think i shoild get 15MM or 10 MM??
Old Aug 31, 2004 | 07:44 AM
these are mm's not inches. Between 10,15,20 little diff. 20mm will make it flush with the rear well, but dude was talkin bout it hits on bumps sometimes. Here,
http://www.opalhut.com.au/shop/en-us/dept_10.html
Its ur car, ur call. I think anything after 5mm u'll need longer bolts than stock, dont knw how much they'll run. Make sure there wheel centric, not those with studs comin out of em. My tire pro never mentioned anything about the wheel possibly coming off, maybe he didn't get the longer bolts.
Old Aug 31, 2004 | 09:23 AM
Colonel's Avatar
Old Fuddy Duddy
I dunno about you guys, but I would do it right the first time.
I needed 5MM spacers for my BBK to get the rims to clear the caliper. Even with my 5MM spacers that are hubcentric I got new wheel studs with the kit H&R.
If you put spacers in, put new studs in. Period. Its not hard. Playing games with safety is stupid.
What I am worried about is wheel bearing wear though. Thats why I have not gotten any for the back. Id LOVE to get it close to flush...but not willing to give up replacing my bearings prematurely.
Old Sep 2, 2004 | 07:36 AM
Mick Max's Avatar
Wild at Hurt
The best spacers are H&R and option auto is a good place to get them. Some spacers are total crap. I have had them on order for 5 weeks as they have been on national back order. I dont think you can get 15 MM
The best total offset for the rear is 25MM and the front 35 or perhaps down to 30, but much less than that is trouble. Of course this can vary some if you have gone a little extreme on your tire size
Old Sep 2, 2004 | 09:41 AM
hmmm i think im just going to put the wheels on and see how that is befor getting spacers. i wont have any issues w/them will i?
Old Sep 2, 2004 | 04:37 PM
ZIPPIN's Avatar
Mauja He Mauja
you should install the wheels and then you will know how thick of spacers you will need. i say 20mm. but it all depends on the offset and how the wheels look
Old Sep 3, 2004 | 06:03 PM
ok thats what im ganna do, the wheels are comming WED ill be away at school by then so im ganna come back on fri and hopefully get them put on on saturday. do u think ill have any issues w/the tires being so big? will the tires rub on the side of the front bumper? 245/40/19
Old Sep 3, 2004 | 06:08 PM
irish44j's Avatar
retired moderator
WHOA! 40-profile 245's on 19's....I am thinking your speedo is gonna be WAY out of spec...your rims+tires are gonna be about 2" bigger in overall diameter than stock....I would think you would need like 20-25 profile tires for 19's, especially in that width..(but I may be wrong...)
Old Sep 3, 2004 | 06:13 PM
I hope they wont be 2 inch bigger cus than i wont be able to use them!!!
Old Sep 3, 2004 | 08:31 PM
Galo's Avatar
Maxima Pilot
If you guys are interested, I can get 12mm custom spacers for around $150-175 not including the extended lugs...I had a shop make these for me in 6061T aluminum, they are hub centric and fit much better than the H & Rs because they are exactly the same OD as the flange on the rear rotors, meaning, they look awesome.
I realize this post is semi-uselss without pics but if you're interested in a G.D., they will be lots less than $150 if I order 10 pieces -meaning five cars worth. You will not be disappointed....everyone who has seen my spacers drops their jaw...
Old Sep 3, 2004 | 11:03 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
pearl if your getting 19's with 40s....no drop your back is gonna fit with like an inch or less and the front will obviously be a little more. i have 235/30/19 and the back is kinda low without a drop....front will be fine though.
Old Sep 4, 2004 | 07:20 AM
im just afraid that the front will rub w/ a 40 size.
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
