Want to color the amber/turn signal on 02-03 tails. How?
Old Sep 5, 2004 | 06:38 PM
NYPD-Arnold's Avatar
Z
Like the subject says, I want to color the turn signals of the 02 tail lights red (like Hamy and QMax03). How is it done?
Old Sep 5, 2004 | 07:10 PM
Tac_M's Avatar
It’s done with special spray paint... like this http://www.streetbeatcustoms.com/bulandtailli.html
Old Sep 5, 2004 | 11:48 PM
Z
Ahhhh, so all I'd have to do is unscrew the tail light, find the turn signal area and spray it red?
Old Sep 6, 2004 | 06:59 AM
dblrr900's Avatar
yep. just use that paint. do it in bursts, about 3-5 seconds at a time. Make sure you point it all around in a circle. It takes about 6-7 coats to match the red and a total time of 15-20 minutes to complete it in. So don't expect it to be red the first shot. It takes about 4 times to see the color change. Do it in the sun of you can, so you can get the best match. Then let is dry for an hour before putting the bulb back in.
Old Sep 6, 2004 | 08:14 AM
mjg's Avatar
mjg
so you didn't have to take apart the housing with a heatgun/oven?
Old Sep 6, 2004 | 08:32 AM
dblrr900's Avatar
Ha Ha. Funny you should ask. Look at the bottom right corner of that light. You see the chip? That is what happens when you try to crack the back lights. You can't. Not at all.
Emax went through two sets of lights I think before he ventured upon this idea and then he posted it. I give credit to Emax for this mod because he did it first and also spent a lot of cash on lights trying.
Just take the bulb out of the back, point the nozzle in and spray. It takes a couple times doing just a 3-5 second burst in circles.
Old Sep 6, 2004 | 04:21 PM
KCMC582's Avatar
when you do this, do you guys let it dry in between each of the 6 or 7 coats? i mean, do one blast for about 4 seconds, and then let it totally dry? let it sit for like, 10 minutes, and then do it again? or wait less time?
Old Sep 6, 2004 | 04:48 PM
dblrr900's Avatar
I was detailing my car when I did it, so I think I let it go for about 5 min each time. Doesnt need much , just enough to set.
Old Sep 6, 2004 | 04:51 PM
Z
Ok, so I should do it like this:
1) Spray around in all directions for about 5 seconds.
2) Weight a few minutes.
3) Spray around in all direction for about 5 seconds again.
4) Repeat Step 2.
5) Repeat Step 3.
Etc etc?
Or do I:
Old Sep 6, 2004 | 06:52 PM
dblrr900's Avatar
Yes. Just spray a bit, wait a few, then do it again until the color matches.
This has to be the easiest mod you can do. Just don't get too agressive on the paint, remember to keep it below 5 seconds of spraying..... you can always add more paint, but you cant remove it once it is in there.
Old Sep 6, 2004 | 07:02 PM
Z
Gotcha. I'm gonna' pick up a can of Testors tomorrow and do it. I can't wait. =D
Old Sep 6, 2004 | 07:19 PM
Hamy's Avatar
Best of luck...I agree with what the others have said for the most part. Just make sure the lights are laying flat on the ground. There are holes in the lense so if you would spray too much it could just run right out into the silver part of the light. Just take your time and it will turn out great!
Old Sep 7, 2004 | 10:00 AM
Max_N_Action's Avatar
isnt there anyway to spray some kind of chemical that will remove the amber color and then stick something in there to scrub all of the color off.....or is it a lens that must b takin out....cuz i think clear would look alot better than all red....there must b some way to do it....
Old Sep 7, 2004 | 07:00 PM
stevay's Avatar
Is that the only good paint to use...what tac m mentioned? To all who have done it what paint have you used? hamy,looslip? i've been meaning to do this for a while just never have got around to it.
Old Sep 7, 2004 | 07:06 PM
Z
Wow...ummm. Bad news. One tail light was completely ruined. Like...completely. The paint leaked into the housting somehow. I have no idea what the hell happened, I did everything right. I waited like I had to. Sprayed like I had to. The other one looks perfect...so I know everything that I did, I did it right. I was kinda' ****ed off...but hopefully I'll find a totalled Max somewhere and lift one from it. *sigh*
Old Sep 7, 2004 | 07:20 PM
stevay's Avatar
I have a fly stuck in my taillight, I hope that doesnt affect anything!!
thing hasnt deteriorated one bit.
Old Sep 7, 2004 | 07:22 PM
dblrr900's Avatar
Dood.... you used Testors??? Oh Man. Sorry to hear about the problem.
I used the lens pain that was shown in the 2nd post. The Japanese crap that you get online. It is $30 a can and it really fine and is hard to run. You should be able to find some 2002-3 lights somewhere to scoop up. I would do both over again and get the right paint. Trust me, the stuff works right.
I also did not take my lights off at all. I left them on the car and just did it right from the trunk. Either way you try is up to you.
Old Sep 7, 2004 | 07:23 PM
dblrr900's Avatar
Yes, get the good paint. Just spend the money, it is only $30 and the can will last for other projects. Light coats is the key with good paint that wont goop up.
Old Sep 7, 2004 | 07:26 PM
Z
Damn. Yeah, the damn spray ran like a fat a** after a donut.
Old Sep 7, 2004 | 07:29 PM
dblrr900's Avatar
Nah. You gotta get the VANS paint. They have two kinds, the Light bulb paint, and the Lens paint. Emax I think used the lens stuff, all I could find was the bulb paint so that is what I used. I liked the bulb paint because it was real thin and layered on nicely. Get it here:
Old Sep 7, 2004 | 07:33 PM
stevay's Avatar
I am planning on getting the "good paint" just want to make sure what the good paint is. I don't 1/2 *** stuff.
Old Sep 7, 2004 | 07:40 PM
dblrr900's Avatar
Stevay - Get the VANS.
Put it this way. That picture above is from spring of 02. My lights still look exactly the same. No new paint needed, nothing. I can even go take a pic of them tomorrow. If you do it right, the dealerships will even miss this one and never even think about it.
I had the service manager looking at my car and he said, your car is different, oh, you took off the maxima lettering, thats it. Then I showed him the lights, he said it was cool. He said that was a clever change and you totally couldn't tell.
Old Sep 8, 2004 | 10:18 AM
stevay's Avatar
Doesnt vans make 2 different kinds of paints that are similar? or am i confusing it w/something else? maybe i'm just too tired and need a nap...this getting up early stuff is gettin to me
Thanks for the info.
Old Sep 9, 2004 | 10:48 AM
Manaz101's Avatar
I'm hoping to do this in the upcoming weeks, i'm going to order the paint tomorrow when i get paid!
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Oct 28, 2019 10:58 PM
BobTX10
Oct 7, 2015 08:43 AM
