abs
Old Sep 6, 2004 | 12:11 AM
altothemax's Avatar
abs please someone has to know were i can start checking please
does anyone have the diagran of the 2000 nissan maxima abs system please reply.or can some one tell me how to retrieve the code from the system.or even reset it?
Yhank You
Old Sep 7, 2004 | 01:50 PM
altothemax's Avatar
this is the deal i did. i changed my starter while changing the abs system whatever its called is around the starter cuss i had to remove the intake stuff to get to the starter. so after replacing the starter ( i did take off the driver front side wheel trying to get a better shot at the bolt that holds the starter).i turned my car on and the abs light stays on.it does do a buzzing vibrating noise when i turn the key to the on position ut not turn the car on, im not sure if it did that before but im pretty sure it did not. so could of i loosen something off? and what should i look for maybe a bad relay i night f hit it or something the nosie goes away after like 3 sec or so when i turn the key switch on anyways can someone please help me out.
Old Sep 8, 2004 | 07:24 AM
altothemax's Avatar
ok maybe if i explain it better someone can help me.when i turn the key on (not starting the car)it goes thru all its normal things abd beeps, but after about 3 sec or so after all the checks i hear the motor or rlay i thing from the abs system and the light comes on and stays on all the time.can it be a bad relay?please help me out someone.
Old Sep 9, 2004 | 09:40 AM
altothemax's Avatar
? anyone please
Old Sep 9, 2004 | 06:59 PM
altothemax's Avatar
someone has to kn ow something please help me out guide me were to start and dont say take it to a mechanic or something like that i want to try and troublshoot it please anyone iceman you help me out once maybe you can give me some pointers
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
