Rear brake question?
Old Sep 6, 2004 | 06:28 PM
kclmax2k1's Avatar
hi everyone,
I replaced the rear brake pads and rotors this long weekend. They seems worked fine, however, when I hit the brake, I can hear some noise like "bo-bo-bo-bo.."
It sounds like "bubbles" or some "pump".
Is this normal?
What should I do to get rid of this noise?
Old Sep 7, 2004 | 10:28 AM
kclmax2k1's Avatar
No one can help me?
Well, let me describe my problem more clearly.
After I replaced the rear pads and rotors, I heard some kind of "clunking" or "knocking" noise when braking. It sounds like "do-do-do-do-do.." or " bo-bo-bo-bo..." or "po-po-po-..."
Beside the noise, everything works fine.
Any idea wha may cause this kind of noise?
Is it possible that suspension not brake makes this noise?
What should I check?
Old Sep 7, 2004 | 11:16 AM
Progress's Avatar
It's business time.
When you say everything works fine do you mean that there is no vibration during braking? Do you have the shims and retaining clips in place?
Old Sep 7, 2004 | 11:30 AM
kclmax2k1's Avatar
I didn't feel vibration. Well, maybe a little.
I am not using stock pads, instead, I use Quietstop pads.
they came with self-adhere shims.
And about the retaining clips, I use the "rear brake hardware kits" from autozone.
Old Sep 7, 2004 | 04:49 PM
kclmax2k1's Avatar
I disassembled and re-install the rear brake this afternoon but no help. The noise is still there. When I brake, I can hear the "clunking" noise.
I suspect that the noise is coming from the suspension not from brake.
I also suspect that ABS cause this noise, however, ABS should not work during light brake, right?
Anyone know what happened to my maxima?
rbuswell
Nov 17, 2016 04:54 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
egali045
Aug 16, 2015 01:19 PM
RealityCheck
Aug 5, 2015 06:18 AM
