Anyway to increase throttle response on a 2k2
Old Sep 9, 2004 | 06:14 AM
Daily Driver2k2's Avatar
I know we have that drive by wire technology, but sometimes i swear when i step on it lately ,it takes a second or two to kick down and respond.I cleaned my air intake,recently changed th plugs, so my engines is in sound condition.I come to the conclusion that is has to be the electronic throttle mechanism not working right. I haven't checked yet , but for starters, would dirt or other funk inbetween the conectors were the wire conector meets the throttle mechanism cause improper or delay for throttle response?
Old Sep 9, 2004 | 07:27 AM
02icarus's Avatar
let me guess, its an auto
Old Sep 9, 2004 | 10:21 AM
Unfortunately yes, but for manuals or auto's both cars use the drive by wire technology.
Old Sep 9, 2004 | 10:37 AM
Progress's Avatar
It's business time.
Maybe a high-flow intake will improve throttle response.
Old Sep 9, 2004 | 11:02 AM
02icarus's Avatar
well if you have auto and you gun it, it will most likely downshift 2 gears and hence the wait. its not manual, you cannot expect instant throttle response. if you really think that you need more response, shift into either 1,2 or 3 on your autoshifter (depending on speed of course) and see how responsive it is.
Old Sep 9, 2004 | 12:07 PM
ChromeSE5's Avatar
I was researching about this and posted this in the general forums but no one replied. Anyways, I read up on google and a lot of websites said to change your plugs to coppers, get indexing spacers for your plugs, high flow intake, high flow exhaust, etc. I am a different case than you are though because I am manual and have the 2k, 2k1 system.
Old Sep 9, 2004 | 07:14 PM
GimmeTorq's Avatar
Did you have the "Lack of Acceleration" TSB taken care off? Check the TSB section in this forum and see if it applies to you car. I did it to mine (it required both the re-programming of the ECU + a new MAF in my case) and it made quite a difference.
Good luck.
Old Sep 9, 2004 | 10:25 PM
MaximaPolak's Avatar
Try reseting the ECU...that might help.
Old Sep 9, 2004 | 11:51 PM
panda_1's Avatar
Good luck.
YEAP VERY MUCH TRUE, HEARD THERE IS A WORLD OF DIFFERENCE AFTER.
TallTom
57
Oct 14, 2025 05:16 PM
trsandrew
Apr 8, 2016 06:45 PM
maxinout93
Oct 31, 2015 02:04 AM
trsandrew
Oct 25, 2015 02:47 PM
