my steering wheel SHAKE... ???
Old Sep 20, 2004 | 02:28 AM
GreekMaxima's Avatar
when i drive on highway i feel my steering wheel to shaking without reason, usualy after 60 miles... im not sure if did it before. Is it normal or not?
Old Sep 20, 2004 | 02:30 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Sounds like you have a tire or two out of balance.
Old Sep 20, 2004 | 02:34 AM
one thing is for sure... my tires are flat!
what do you mean "out of balance"?
Old Sep 20, 2004 | 02:36 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Read this article and see if it may be what you have going on.
Old Sep 20, 2004 | 02:43 AM
thanks man, can dealer fix it under warranty?
Old Sep 20, 2004 | 02:51 AM
SEmy2K2go's Avatar
Go BUCKS!!!
No, this is something that you can take your car to any tire shop and have them check your tires to make sure that they are balanced properly and are in good condition.
do you know how much it will cost me?
Old Sep 20, 2004 | 02:58 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Will depend on where you go. Not sure off the top of my head.
Old Sep 20, 2004 | 03:55 AM
Ryans Maxima's Avatar
Before you even go balance them, you said your tires were flat, I would suggest checking pressure all around to make sure its consistent and that one wheel isn't signifigantly lower than another.
Old Sep 20, 2004 | 04:02 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
6 dollars per tire at Walmart ickudib=ng ratation....... 9 dollars balace per life I think...... take it to Walmart they will fix your problem
Old Sep 20, 2004 | 12:39 PM
StAtiXz6's Avatar
steering wheel could also shake if u have a bent rim
Old Sep 20, 2004 | 12:42 PM
scopium
do u have after market rims?
might be the lack of hub rings
Old Sep 20, 2004 | 01:27 PM
SoonerFan's Avatar
Cletus
could also be warped rotors.
go get your wheels balanced first. if that doesnt help then you might need to turn your rotors. any garage will be able to do both
Old Sep 20, 2004 | 01:36 PM
my rotors are fine. I got my stock rims.
I will gwt new tires soon!!!
Old Sep 20, 2004 | 01:47 PM
how do you know your rotors are fine? you cant tell by just looking at them.
its a huge problem on our cars
i have aftermarket rotors. im not talking when i press the brake pedal but when i drive fast -my foot on the gas pedal- i feel my steering wheel to vibrate
Old Sep 20, 2004 | 01:50 PM
SoonerFan's Avatar
Cletus
didnt realize you had aftermarket rotors.
mine were warped and it vibrated at high speeds (60) like you were saying. nothing when i pressed the brake. thats why i thought it might be that.
Old Sep 20, 2004 | 01:59 PM
i think its the balance, thanks anyways!
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
