BBK pros please answer my questions
Old Sep 20, 2004 | 01:13 PM
scopium
ok i'm in the process of gettin my "custom" bbk together
i have the 300zx calipers..
i dont know what rotors to get
300zx - i have to mill it down a bit..
i'm hearing cobra rotors are bolt on .. true/false?
what else do u guys recommend
thanks
Old Sep 20, 2004 | 06:07 PM
irish44j's Avatar
retired moderator
did you check matt blehm's site? www.mattblehm.com...he has a conversion kit to use Z calipers with 2004 maxima rotors....
Old Sep 20, 2004 | 06:54 PM
Larrio's Avatar
The Definitive AE Master
thanks
any BBK utilizing the 300zx calipers with bigger rotors will require a bracket of some sort to phase out the caliper to accomodate.
the cobra kit is made by jeff92se, but you'll need the hub centric rings from candiman so that cobra rotors sit properly on the hub. This "kit" has no hardware, no lines, no specific company. You'll need to find the 13" cobra rotors yourself.
the blehmco kit is straight up bolt on with brackets, hardware, and lines. You just find the 12.6" 2k4 maxima rotors yourself from www.irotors.com. It is a reputable company by matt93se
the Z caliper and rotor upgrade require 0.2-0.4 inches milled off the diameter of the rotor (most go with 0.3"). You'll also need to grind down a little off the suspension area cause one part of it rubs
Old Sep 20, 2004 | 08:04 PM
scopium
thanks guys..
i guess i'll just got with the 2k4 rotors
Old Sep 20, 2004 | 09:35 PM
Pri63's Avatar
I have 04 Slotted and Drilled that I'm selling if you're interesting PM me
BkGreen97
Apr 2, 2016 05:47 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Spartan1310
Sep 28, 2015 08:03 AM
pears
Sep 18, 2015 05:25 AM
boomerbrian
Sep 4, 2015 08:25 AM
