those of you who switched your tail lights...
Old Sep 23, 2004 | 09:52 AM
KCMC582's Avatar
do you need to get new wiring harness for all 3 lights on each side?
i havent taken a look at the tail lights yet, i will when i get outta work, but do the brake, signal, and reverse harness all need to be switched when going from 02 to 01 lights?
Old Sep 23, 2004 | 10:25 AM
xtantmaxima's Avatar
all the same, just need new sealer.
Old Sep 23, 2004 | 10:57 AM
mjg's Avatar
mjg
i didn't reseal mine, there was enuf of the black gunk left on there to seal it up good.
(did this last weekend)
Old Sep 23, 2004 | 10:58 AM
KCMC582's Avatar
cool, so BOTH you guys didnt have to change wiring?
mjg, you put in the 01 tails on your 02? it was plug and play, just make sure the sealant is there? thats good news
Old Sep 23, 2004 | 11:32 AM
Maximadmoiselle's Avatar
First question is, did you get only the SE housings without the bulbs/harness? If that's the case, here's the deal. The harness for the 00/01 and 02/03 is the same, 2 of the bulbholders are the same, but the third one (for the turn signal) is different. The 00/01 has a clear lense and a yellow turn signal bulb (size 1156A). The 02/03 has a yellow lense and white bulb (7440). Therefore, you'll have to go to Nissan and order the 00/01 wiring harness, or better get it from someone on here. The other end of the harness plugs right in here (whosever Max this is):
PM me if you have any questions.
Old Sep 23, 2004 | 11:50 AM
KCMC582's Avatar
i just PMed you back moiselle, but it wasnt about this
so if i go to the dealer, or on here, and get the wiring harness, it will plug into that piece, and have the 3 connections i need to fit the 00-01 tail lights (brake, signal, reverse)...if i DONT get that harness, ill need to ghetto rig a 7440 bulb into a 1156A whole, or cut and splice and be a PITA. one of the nissan websites has that wiring harness for $15 or so, i just want to make sure im getting the right thing.
Old Sep 23, 2004 | 12:25 PM
The thing is that the 1156A amber bulb & bulbholder are larger and they don't fit into the 02/03 hole, and vice versa the 02 bulbholder is a tad smaller. You might be able to retrofit it into the 00/01 hole and use a 7440 bulb, but you need to find an amber one. Just get the wiring harness from Nissan, mine cost 30 and some change for both 03 harnesses. I'd send you mine, but was told by parents to "keep the tails in case you ever need to go back to stock". Whew. Once you get the harness kit, you'll be able to use your stop light (dual filament, 7443) and reverse light bulb (don't know the number).
And one little trick, before you start pushing the old tails out, remove the bulbs. I screwed up my dual filament bulbs and had to buy new ones because they're so fragile.
Old Sep 23, 2004 | 12:31 PM
KCMC582's Avatar
so the harness has one end that plugs into that connector in your picture, and then branches into 3 ends for each lens?
Old Sep 23, 2004 | 12:38 PM
mjg's Avatar
mjg
Mine came with the harness, and everything (except one reverse bulb which was the same as my 02).
Totally plug and play. Already rained so far, no problems, I also washed the hell out of my car.
edit nm.
I'm putting in piaa hyperwhites for the turn signals this weekend. I love the red/clear look, on a black car it's awesome.
No force to pop them out, the black gook stretches and looks like nasty crap, and thats it. You will want to clean the bulbs/outter plastic when u remove/replace. I used 3m bug and tar remover stuff, did the trick.
Old Sep 23, 2004 | 12:48 PM
KCMC582's Avatar
where did you get yours with the harness from mjg?
Old Sep 23, 2004 | 12:57 PM
mjg's Avatar
mjg
i sniped them on ebay. I got an awesome deal, heh almost awesome (61 bux, then 20 bux shipping from brooklyn!) hah, well it was 6 bux costs shipping, yet the new knockoff ones, and some crazy guys try to unload theres for way more.
Arnold found the auction for me, thanks again bro.
Old Sep 23, 2004 | 01:16 PM
KCMC582's Avatar
aw man...was it someone who is always on there, or just a guy sellin them?
Old Sep 23, 2004 | 01:24 PM
MIXXMAX's Avatar
Yes, the tailights are totally plug-n-play. I swapped my '00 SE for the '02-'03's. I bought the plug harnesses for both and they plug right into the stock connector with no problems. You'll save yourself some time if you get the harnsess. It only costs between $15.00-$18.00 from Nissan. Like someone said before, the sockets are different from the '00-'01 and '02-'03's.
Old Sep 23, 2004 | 01:29 PM
mjg's Avatar
mjg
he had some ebay store that sells movie stuff. He wasnt a car parts dealer, they were his personal lights. THey are perfect! : ]
Old Sep 23, 2004 | 01:36 PM
Yup and each end has its own bulbholder. You'll just need to buy the amber bulb, or what you can do is find a clear one that blinks amber, which is much better looking, or spray the amber one with a couple of silver paint coats. It will still blink amber.
Pushing the stock tails out was a PITA, don't ask me how I did it. The lens is being held by 4 nuts and the sealant, so first you unscrew them. Here's a good writeup with pics.
http://www.kevinfisher.net/web_serve...light-mod.html
Old Sep 23, 2004 | 01:46 PM
KCMC582's Avatar
ill think ill get the hyper white bulb, to complete my hyper white look, but im not really sure. we might do the silver/orange thing. who knows. thanks moiselle
Old Sep 23, 2004 | 05:34 PM
NYPD-Arnold's Avatar
Z
=D You're welcome.
Old Sep 24, 2004 | 04:23 AM
aliti19's Avatar
Maxima addiction cured w/ the GS pill
If you're gonna swap tailights w/ another person, there is no reason to buy anything extra. Keep the harnesses together with the tails and there will be nothing to buy.
gavin68
Sep 18, 2021 12:36 PM
AaronL
Aug 8, 2020 10:31 AM
Fbana41
Aug 29, 2016 12:18 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
