Passanger window....SLOW!!!!
Old Sep 25, 2004 | 03:10 PM
nexus_7's Avatar
and getting slower.
I am about to replace my speekers so I wil lalready have the door panel off. WHat should I look for? is it just a dirty moter or does it need to be replaced?
Sugestions, Ideas, links (sorry if this has been asked already)
Thanks in advance.
Greg
Old Sep 25, 2004 | 03:36 PM
NYPD-Arnold's Avatar
Z
Probably just a motor with some gunk in it that could use some cleaning and a little oil.
Old Sep 25, 2004 | 06:19 PM
ZIPPIN's Avatar
Mauja He Mauja
is it slow from both controls? mine is slow when the pass control is used. from drivers control it is fine
Old Sep 25, 2004 | 06:33 PM
irish44j's Avatar
retired moderator
not the motor....
here's what you do:
1. spray silicone or lithium grease in the track (both sides of the window)
2. clean the inside edges (the kind of "fuzzy" side of the rubber seals at the bottom of the window (I find that using carb cleaner to do this will remove ALOT of gunk that accumulates there)...
3. use silicone detailer on the outside of the rubber seals to keep them pliable and so they won't dry out and become stiff.
I do these 3 things every 3 months. I just did it yesterday...my driver's window was getting REAL slow. Now it's fast as hell!
Sure, your motor could be going bad I guess....but do the 3 steps above and see if that fixes the problem before you go taking apart electrical components...
Old Sep 25, 2004 | 07:45 PM
foodmanry's Avatar
Da Roller Coaster!
Hey Irish....to do the track should you have the window up or down? ALso where do you spray exactly? Need to have the door panel off to do this?
Old Sep 25, 2004 | 07:49 PM
irish44j's Avatar
retired moderator
window down....obviously can't spray the track if there's a window rolled up in it
if you buy silicone spray at an auto parts store it should come with a little straw-looking thing you stick on the nozzle so you can direct the spray more precisely...just spray a bunch of it in the track...it comes out in liquid-ish form so it will flow down the track. then just roll the window up and down a few times to spread it around....the next day the window should go up/dn smooth and fast (if you do the other things I listed too....) once the silicone "dries" a little and is stuck to the track.
it'll wear off eventually, so I'd suggest to just give it a spray every so often.....
Old Sep 25, 2004 | 07:51 PM
Andrew's Avatar
I have the same problem. Its mad slow. All the other windows roll up faster than the passenger. I'll try out Irish44's suggestion. Anything to get this thing working faster.
A-
Old Sep 25, 2004 | 11:00 PM
superpaul33's Avatar
Has anyone had a problem or advice in installing a rear strut bar from stillen? Like tightning aduster nuts inbetween those ugly black bracket. Also any recommendations on keeping the two nuts from not coming off??? Thanks for any ideas....
Old Sep 25, 2004 | 11:05 PM
Andrew's Avatar
umm...
dude..
not to burst your bubble..but wrong thread!
A-
Old Sep 26, 2004 | 07:19 PM
nexus_7's Avatar
LOL superpaul33...where that come from.
Thanks for the advice. Ill give that a try tomorrow.
Greg
Old Sep 26, 2004 | 07:41 PM
nexus_7's Avatar
Ya know. it is always the passanger door on my car. I have to lube its hindges, now the window rails....probably other junk I cant think of.
Stupid door.
Greg
NYCe MaXiMa
27
Nov 1, 2024 09:11 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
tifosiv122
32
Nov 11, 2001 08:32 PM
Mike S.
Feb 19, 2001 10:12 AM
