Sun roof problem
Old Sep 25, 2004 | 11:17 PM
chuckd2k's Avatar
Sun roof problem
My sunroof is acting up. When I hit the slide switch, it moves about two inches and stops, I have to continue hitting the switch to get it all the way back. Also after going through the same process to close it, if I hit the slide switch one additional time it tilts the glass up.
If anyone knows what going on with it, your info would be welcomed.
Old Sep 26, 2004 | 08:12 AM
Jeraldo's Avatar
Have you tried resetting it.
1) close it. and have the power (ignition) on.
2) Of the two switches, one slides and one tilts right. We want the tilt switch here. Of the switch, there's an up or open, and a down or closed position. Push the closed or down side of the tilting switch and hold it closed for five seconds. You won't get any feedback that anything has happened, audible or otherwise.
3) try it again. Might fix it.
Jerry
Old Sep 26, 2004 | 08:14 AM
Gsilk's Avatar
Reported
i think there is a TSB for that problem. check the stickies at the top of the forum. maybe this link will help you. http://applications.edmunds.com/main...tep2.9.Nissan*
Old Sep 26, 2004 | 10:44 AM
ihavea5spd's Avatar
ok, here's what you do. close your sunroof. unhook your battery. stomp on your brakes a few times. turn your lights on and off. (you're draining the power
in the system). hook your battery back up. turn on your ignition. tilt the sunroof
up, and then back down. now it'll work.
the reset procedure that was listed above isn't the same for the 5th gen as it is for the 5.5 gen.
Old Sep 26, 2004 | 02:24 PM
chuckd2k's Avatar
Dude you rock!
It's working again, thanks for the info.
Old Sep 26, 2004 | 08:13 PM
ihavea5spd's Avatar
Originally Posted by chuckd2k
Dude you rock!
no sweat. most dealers will NOT know how to fix that.
but they'll be more than happy to charge you $300 for a
new sunroof motor.
Old Sep 26, 2004 | 08:31 PM
nexus_7's Avatar
LOL, that is the stupidest thing EVER! good deal on fixing it..but that is Beyond stupid. LOL
Greg
Old Sep 26, 2004 | 09:42 PM
A'sMax's Avatar
WOW , I had same problem for a months and now i just fix it
Thanks.
Old Sep 27, 2004 | 05:24 AM
ihavea5spd's Avatar
that same problem comes up every once in a while. it should really be in the
how-to section.
Robert Schneeweis
Jan 11, 2017 06:47 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Vequity
Sep 10, 2015 05:26 AM
