what brand to replace my warped rotors with???
Old Sep 26, 2004 | 06:42 PM
blackmaxgic's Avatar
It's time to replace the oh so common warped rotors on my 2k2 max. I do not want to buy factory replacements as they seem to warp w/i six months to a year according to the other war stories on this model.
My mechanic tells me that the chinese made rotors warp easily and I should go with more expensive american made. Not sure what brands are American made. For some reason the "Brembo's" which are made in Italy seem to be mentioned in most sport's car forums. The question is for you all who've upgraded from factory rotors, which rotors/pads did you go with and would you buy them again?
Thanks for the input I want to hopefully buy 'long-lasting' brake rotors.
Old Sep 26, 2004 | 07:17 PM
theMax's Avatar
No such thing as long lasting but, the aftermarket ones will last longer than stock but eventually will warp. Brembo makes a good rotor.
Carefull driving and good break in will make them last longer, and avoid puddles after braking.
Old Sep 26, 2004 | 07:50 PM
ICULookN's Avatar
Brembo does not make rotors for the 2k2/3 for the front as of now. Try Irotors, they have a decent deal for the front/rear on ebay.
Old Sep 26, 2004 | 08:22 PM
Trance Artur's Avatar
http://www.frozenrotors.com/
Old Sep 26, 2004 | 08:32 PM
maximo-SE's Avatar
i know frozen rotors are great, but they are pretty expensive..... a friend on the org gave me this website for 2003 BREMBO BLANKS for 56.99 each. Its pretty good IMHO.
link is - http://www.importrp.com/catalog.php?...s&subcat_id=11
I have one question though, the front would wear more, so can i change the front rotors then the rear later.... or should i just change them both at the same time?
Old Sep 26, 2004 | 09:04 PM
FusionAcid's Avatar
change the front only! no need to change the whole system. Rear's last atleast twice as long. thank mr.frontwheeldrive.
Old Sep 26, 2004 | 10:43 PM
maximo-SE's Avatar
oh i c... thanks a lot.
Old Sep 26, 2004 | 11:17 PM
MaximaPolak's Avatar
I have Irotors....Check them out....
and here on the car....
Old Sep 26, 2004 | 11:22 PM
GreekMaxima's Avatar
I got powerslot. they're great rotors and i got them cheap as well
Old Sep 27, 2004 | 01:22 AM
SEmy2K2go's Avatar
Go BUCKS!!!
I also picked up a set of front and rear x-drilled and slotted black zinc coated rotors from www.iRotors.com. No complaints as of yet (1k miles roughly).
Old Sep 27, 2004 | 02:36 AM
Triple8Sol's Avatar
I miss the .org!
Got mine from "maxed up" here no the .org. Cross-drilled/slotted. Got a pair for not much over $100. Pics on my cardomain...
Old Sep 27, 2004 | 03:29 AM
i got my rear rotors from him, he is a cool guy!!
Old Sep 27, 2004 | 04:46 AM
Qmax03
cant seem to find rotors for 03 max on irotors
Old Sep 27, 2004 | 07:23 AM
If buying from Irotor, select the option you want then write to them what year your car is....or look on ebay...they have them there.
Old Sep 27, 2004 | 03:48 PM
maximo-SE's Avatar
Hey triple, can you give me that persons contact info. I actually want to get a pair of front 2003 rotors. Slotted only though.
Old Sep 27, 2004 | 07:37 PM
Ben's Avatar
Ben
Pad selection is at least as important as rotor selection.
Keep in mind, it is not that the rotors actually warp, the problem is material from the pads transfering to the rotor and fusing there. If you get higher temp pads, that problem is reduced as well.
I went to Hawk HP pads with brembo blanks and I have been very happy even for the occasional autocross.
Old Sep 28, 2004 | 08:57 PM
GimmeTorq's Avatar
This is a good article that covers what you just mentioned.
http://www.stoptech.com/whitepapers/...otors_myth.htm
I just installed Hawk HPS with OEM rotors in my '02. Right now it feel great but I have to wait and see how this combination performs in the long term.
Old Sep 28, 2004 | 09:11 PM
Triple8Sol's Avatar
I miss the .org!
His name is Henrik and his .org sn is: maxed up
All his styles of rotors are listed on his cardomain right here:
http://www.cardomain.com/memberpage/342829/2
Tell him I sent ya
Matt93SE
May 24, 2019 02:58 PM
03VQMAX
Sep 25, 2015 04:19 PM
Maxima_no_more
Aug 15, 2015 05:37 AM
RealityCheck
Aug 5, 2015 06:18 AM
