Turn signal
Old Sep 27, 2004 | 10:45 AM
odspins's Avatar
Turn signal
My hazards and turn signals stopped working. Any suggestions?? :attention
Old Sep 27, 2004 | 10:53 AM
al7601's Avatar
check your fuses
Old Sep 27, 2004 | 06:11 PM
ajsince81's Avatar
Want to hear something weird? After my new headunit was installed, my left turn signal stopped working and my hazards did not work. After two days of being pi**ed off and no time to deal with it, everything started working fine again. I can't figure it out. Thats the second time that has happened to me.
Old Sep 27, 2004 | 06:15 PM
Gennady7's Avatar
possible short somewhere in the wires ajsince81?
check fuses odspins.
If that does not fix it. The emergency blinker light switch (makes both side signals go on at the same time) has either diconnected or broke. It is located near your shifter on the dash pane under your climate controllerl. Happened to me before.
Old Sep 27, 2004 | 06:35 PM
ajsince81's Avatar
Thanks for the info Gennady7. Im not to worried right now because everything works fine but if it happens again I will check everything over.
P.S. whats odspins?
Old Sep 28, 2004 | 07:02 AM
Gennady7's Avatar
odspins is the dude who started this thread. He should check his fuses
Old Sep 28, 2004 | 07:32 AM
MaximaPolak's Avatar
Did you put the bulbs back in? That could be your problem. If not then the fuses.
Old Sep 28, 2004 | 10:43 AM
ChromeSE5's Avatar
did you do any stereo work? Check to see if you plugged your hazard button back in.
Old Sep 28, 2004 | 11:20 AM
neonon17s
I got a strange one. I drive a 98 Neon and my indicators or hazards do not work unless it is approximately 80-85 degrees. Where is my problem?
P.S. This has been going on for over two years.
Old Sep 28, 2004 | 11:47 AM
odspins's Avatar
Thanks a bunch
I think my fuses are working fine. None of them are broken, but I have had some stereo work in the past. I'll have to check if everything is plugged in.
Old Sep 28, 2004 | 01:40 PM
ChromeSE5's Avatar
One time i was working on my stereo and forgot to plug in the hazard button. I was driving around and my signals wouldn't work and there was a cop on the other side of the intersection. I plugged it in after i parked and then viola, it worked.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
