Need help again in interior lighting...Blkmax95c please step inside
Old Sep 30, 2004 | 02:08 PM
Bl_asd's Avatar
sigh... I have some problems with the interior lighting, ok..so sharpie doesn't work too well for me...it fades.and too dark. i have 3 coats and it fades a little bit in 2 weeks. I just got 50PC of blue LEDs .
Problem No.1
I have to use 330 Ohm 1/4 Watt resistors right? How do I connect them with Led lights? Which leg should I use to connect the resistor?
Problem No.2
How Can I replace these LEDs into the stock little radio bulbs' places for the power source?
Blkmax95c I know you have done this..please help me or anybody knows how to do this..thank you.
Old Sep 30, 2004 | 02:17 PM
D Love's Avatar
Originally Posted by Bl_asd
Problem No.1
Power, Resistor, Long Leg, Short Leg, Ground
Old Sep 30, 2004 | 02:22 PM
Bl_asd's Avatar
hmm..I'n not sure what you are talking about... so how could I do it?..
Old Sep 30, 2004 | 03:42 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You need to find which ends are the positive and negative ends on the circutboard. Solder the resistor to the long end, which will be positive. The short end will be the negative end. Solder the respective ends onto the circutboard.
If you do not understand this then please consider redoing the interior...you have some homework yet to be done.
Old Sep 30, 2004 | 03:53 PM
Bl_asd's Avatar
yes, I'm redoing this. This is the first time I do those lighting stuff with a circutboard... I understand the resisitor and LED positive and negative legs now. I have 1 more question, How can I find out which side is positive or negative on the circutboard? When the radio face is taken off and let the circutboard faces you. The positive side is on the right or the left? Thx for info.
Old Oct 2, 2004 | 04:18 AM
Bl_asd's Avatar
ok..so the side with [ is negative side...but how do i put my led in? do i have to remove the old light bulb and how to connect led and resisitor in that little socket? please help......
Old Oct 2, 2004 | 04:39 AM
custommaximaSE's Avatar
Man this is going to be hard to explain to you .
Old Oct 2, 2004 | 06:51 AM
Bl_asd's Avatar
well...i don't have much knowledge in eletronic stuff, could you please try to explain it?
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
BobTX10
Oct 7, 2015 08:43 AM
