How to on spark plugs for a 2000
Old Oct 5, 2004 | 11:25 AM
sarmstrong's Avatar
Sorry guys, I back tracked 25 pages and can't find the 'how to' a member made for changing plugs on a 2000. He had step by step instructions with pics.....any idea who it was?
Old Oct 5, 2004 | 02:22 PM
ZIPPIN's Avatar
Mauja He Mauja
me
http://www.nissanx.net/tanman/
Old Oct 5, 2004 | 03:31 PM
nexus_7's Avatar
dont forget the Anti seize on every plug!!!!!!
took me about a hour...and it was the first time I did any plugs.
Greg
Old Oct 5, 2004 | 03:33 PM
Yaco_Max's Avatar
OUch my back still hurts when I remember that I could save some money do it by myself!!!!!! Never ever again!!!!!!!1
Old Oct 5, 2004 | 03:39 PM
ZIPPIN's Avatar
Mauja He Mauja
i can change them in 20 minutes. have done it 4 times. the rear ones do put the hurt on the back. last time i did them, i laid on the bay, and used the wall to support my feet. it was easier on the back...
Old Oct 5, 2004 | 04:06 PM
spirilis's Avatar
lol laid on the bay... I must be too fat (or maybe I don't have the nerve) to do that
I've pulled that stuff out at least 3 times now... first time to do the plugs and coils, second to do a compression test, third time to change the plugs again (used copper, they generally aren't supposed to last beyond 30K miles or so, although you could probably get them to if you file & regap them) and do another compression test
It gives your lower back a workout but as long as you're not in bad shape, it's probably worth it.
Old Oct 5, 2004 | 05:34 PM
SoonerFan's Avatar
Cletus
people need to read their owners manual before they ask questions..this one is in there
Old Oct 6, 2004 | 07:16 AM
sarmstrong's Avatar
Thanks....anti-seize, not sure what that is...but I see it must talk about it in my manual...I'll read it today.
Old Oct 6, 2004 | 07:29 AM
Progress's Avatar
It's business time.
Where does the anti-seize come in?
Old Oct 6, 2004 | 08:50 AM
00gxe5sp's Avatar
don't forget the plug wires.
hahahahahaha
Old Oct 6, 2004 | 11:26 AM
sarmstrong's Avatar
Found it............Anti-Seize Lubricant
Champion Sprayon® Anti-Seize Lubricant is a preventative maintenance product intended to be used before corrosion or severe rusting develops, or as a high-pressure lubricant on surfaces subject to seizing or galling. It is a unique formulation that is effective through a temperature range of 65°F to 2000°F.
Protects against extreme heat, galvanic pitting, corrosion and rust
Eliminates seizure of threaded parts
Dry lubricant with graphite and molybdenum disulfide
Conforms to military specifications MIL-A-907E
Recommended Uses
Use on any threaded parts, including those in automotive, farm and construction equipment, and in industrial machinery. It’s formulated for factory, institutional, industrial and commercial use.
Old Oct 10, 2004 | 07:32 PM
Bl_asd's Avatar
so...we rub those anti-seize on our plugs or?..
Old Oct 10, 2004 | 09:20 PM
aussie983's Avatar
put it between the electrodes of ur plugs
J/k
Youre supposed to smear a tiny amount on the threads of the plug, so that it will be easier the next time u change them. Notice the first time u take them out, its a bit stuff cuz they are stuck on due to corrosion.
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
